Hi guys, i am currently getting bits and stuff together to upgrade my water cooling.
I was planning on taking off the heatpipe from my motherboard (Msi P35 Neo 2 FR), and putting a water block on the NB, but a friend on another forum gave me this idea.
His original idea was just to have the tubing running through the gap on the heat pipe, and secured down with cable ties.
After some further thinking i thought of possibly getting some copper piping and having that in the gap, with the tubing connected at both ends, as the copper would probably be better then just the tube alone. And possibly a fan ontop of the pipe/heatsink for added cooling too.
Idealy i would like to keep the heatpipe there, as it cools the SB/NB and Mosfets, cooling the SB/NB is easy enough with water blocks but i can't find any compatable with my mosfets, so thats why i was thinking of this (plus costs, this idea would be cheaper then seperate blocks).
Basicly my question to the more advanced water cooling guys here, is if i was to do this idea, would it aid the cooling of the heatpipe or not, or would it just basicly not do anything?
