- 25 Nov 2010
- Lancashire
Problem:
Trying to fix a friend's kid's netbook, which apparently became riddled with malware and when he ran an AVG scan, the subsequent reboot failed to properly load Windows. (Windows XP)
It POSTs, it gets to the Windows loading screen with the scrolling blue bar, then black screen and auto-restart. I can get into the F8 menu, but Safe Mode (and variations) all do exactly the same. Safe mode lists a lot of drivers as they are loaded, but then stops and restarts.
I suspect the netbook originally came with advice to create a recovery disc, but (a) this wasn't done, and (b) it has no disc drive.
My questions are these:
1) Can one download a set of recovery files to use as a boot-from-USB, to save the machine? It has the WinXP product label with key on the underside.
2) Failing that - I have an old copy of WinXP with product key, that was the O/S on an old (now dismantled) PC. Can I somehow create a bootable USB from this and use it to recover the netbook?
The machine is an eMachines 250-01G16i.
Any advice very much appreciated!
