Hey guys, just wondered if any of you experts know if its possible for me to get my ram upto the full 1600mhz, after my overclocking it has dropped to 1445mhz. Now it could well be a setting in the bios that i need to change, but im still fairly new to overclocking and am unsure as to what im missing. My specs are below in my signature. But the i7 860 is now at 3.8ghz stable. Here are my bios settings, if ive made a mistake or would be better off changing an options please someone tell me what it is i need to change.
Bios Settings
Cpu ratio - 21
Speedstep - disabled
Xtreme phase full power mode - Enabled
BCLK Freq - 181
Dram Freq - 103
Qpi Freq - auto
Oc Tuner limit value - good performance
Dram timing controls
dram cas latency - 9 dram clocks
dram ras to cas delay - 9
dram ram pre time - 9
dram ram act time - 28
dram ras to ras delay - auto
dram red cycle time - auto
dram write recovery - auto
draw read - auto
dram four act win time - auto
dram timing mode - 2N
Everything else on Dram option Auto
Cpu Differential amplitude - 1000mv
Cpu Clock Stew - auto
Cpu Voltage Mode - manuel
Fixed voltage - 1.35000
Imc Voltage - 1.17500
Dram Voltage - 1.6500
Cpu PLL - auto
Pch Voltage - auto
Load line calibration - Enabled
Cpu spread spectrum - Disabled
Pcie spread spectrum - Disabled.
So if i try to put the ram upto 1600 with these settings it fails to boot. So obviously for that to happen i must need to change something. Please can some of you experts point me in the right direction.
Thanks for your time guys.
i7 860 @ 3.8ghz
8 gig ddr3 corsair xms3 1600mhz @ 1445mhz
Asus evo motherboard
Zalman cnps cooler
coolermaster m700 real power psu
Other info below.
Bios Settings
Cpu ratio - 21
BCLK Freq - 181
Dram Freq - 103
Qpi Freq - auto
draw read - auto
Cpu PLL - auto
Pch Voltage - auto
i7 860 @ 3.8ghz
Zalman cnps cooler
Other info below.
