I'm looking to add a cheap GPU to a second system - just for some very light gaming at 1080P. Had roughly settled on an Asus GTX 960 Strix - mainly because it only uses one 6-pin for power, and seemed about as good as I could get at a low TDP, and below £200.
What worries me is, my power supply. I'm using a Seasonic G series 360w '80 Plus Gold' unit: https://www.overclockers.co.uk/seasonic-g-series-360w-80-plus-gold-power-supply-ca-020-ss.html
Obviously, it's not like it's a cheap piece of garbage...but I'm worried that 360w might be cutting it pretty fine, even with a GTX 960 (I really didn't buy the power supply with any intention of using it with anything other than integrated graphics at the time).
System spec - which is a bit of a hodge podge of parts - is as follows:
3770K (currently at stock)
K2 Mount Doom cooler (stock fans)
ROG Maximus V Formula
8GB (2X4GB) Samsung Green DDR3 (also at stock)
128GB Samsung 830 SSD
500GB Seagate 5400RPM mechanical
No optical drive
Really just wanted some feedback to either reassure me - or tell me I'm probably playing with fire I've tried various power supply calculators...and some seem to say I'm just about ok (as long as I don't overclock); others seem to imply I'd need more like 380-400w. So, any help or suggestions would really be much appreciated!
No optical drive
