Is this PSU powerful enough for my system?
TNdLbOZK
You should be OK. Have you already got that PSU?
http://www.overclockers.co.uk/showproduct.php?prodid=CA-039-CS&groupid=701&catid=123&subcat=1084
Should be ok, but id get...
XFX Pro 850W Core Edition '80 Plus Bronze' Power Supply
This Week Only Offer
was £89.98 inc VAT
£79.98 inc VAT
http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-XF&groupid=701&catid=123&subcat=
or
Lepa B-Series 850W '80 Plus Bronze' Modular Power Supply - with FREE LEPA Hard Drive Enclosure
£99.98 inc VAT
http://www.overclockers.co.uk/showproduct.php?prodid=CA-007-LA&groupid=701&catid=123&subcat=
Thanks for your response Lemin, what warrants the price difference between these two?
From what I understand Lepa use Enermax platforms, so they will be high quality.
Had my share of faulty Antec units so tend to go XFX or Corsair for the longer warranties more than anything. The Corsair TX750W V2 is a good solid value fixed wire model with a 5 year warranty, it is what I'd recommend if you are not fussed about modular.
Thanks for your response jamesfreddie. No I am running the PSU in my sig, I knew I was scrimping but was on a very tight budget. I've run this PSU for 4 yrs & it's led an active life so must be putting out less than 600w.
I've seen the one you linked to on a competitor site for £99 inc VAT & they have a shop in my city, but looking at the specs it says only 1 12v connector. I need either 2x pin or 1x 8pin 12v to power the mobo. Corsair site doesnt really give much more infor & all the pics everywhere seem to display PSU's without the blooming wires. Has this PSU got all the connectors required? (apart from the second 8pin PCI express adaptor which I already have).
Cheers
its http://www.overclockers.co.uk/showproduct.php?prodid=CA-009-LA&groupid=701&catid=123&subcat=2057 thats enermax made the b-series you suggested isn't enermax made.
go with the xfx 850w for £80 tho, it goes back up in price tomorrow afternoon so hurry.
