Is this RAM compatible with my system?
30 May 2012
Bristol
Hi, I currently have G.Skill F3-12800CL9D-8GBXL memory (2x4Gb Red kit) on my P8Z77-V motherboard. I am planning on buying F3-12800CL9D-8GBXM (2x4Gb Blue kit) so that it matches my motherboard better. These two kits seem almost identical, apart from the fact that the Blue kit is a 1.35v kit as opposed to 1.5v for my current sticks. I looked at the Ram support list for my motherboard and neither are listed. Will this new blue kit work fine on my motherboard (bearing in mind it is 1.35v not 1.5v- so isn't exactly the same as my current sticks, which works fine btw). Hopefully someone (8 Pack if you're out there!) can shed some light on this matter. Thanks :)
Yes that RAM will work absolutely fine at XMP on that motherboard.
hey its 1.35v maybe its Samsung IC ;) it might clock quite well too then.
