- 17 Jan 2006
I have been given a couple of old computers from work, which they were getting rid of. They're not a massive spec but they were free and perfectly good for what I want (basically just to connect up with a scanner to give me adedicated scanning computer). I plugged in an external hard drive, and found that the onboard usb ports on the mother board seem to only be USB 1.1. (seeing as it took a good few mins to copy across some software I wanted on the new comp.
I just spoke to one of the IT chaps at work and he said that it would be possible to upgrade the drivers to USb 2.0 as the hardware is the same...is that true???
He reckons that if I go to control panel>System>hardware and go to the properties for the USB controller, and delete the drivers (not the intel ones he said), then reboot, it should find the newer drivers and will be updated to USB 2.0. This is using windows 2000 SP4.
It shoulds a bit fanciful to me, is it true???
Valve
Valve
