is this right?
11 Jul 2005
London
I have a qx6800 and according to Speed fan temps idle are around 30-40 and load are 40-50, according to coretemp idle are 45-50 and load are 60-65 which one is correct, and are these the correct temps, my bios agrees with speedfan
Daniel
well I always go with coretemp if in dout..
what Tjunction is coretemp reading on that CPU? would check that its correct and if it is go with coretemp readings
Tjunction is the temp at which the CPU will shutdown, thermal protection normally kicks in 5/10c prior to this point..
As far as I can see from a quick google search Tjunction for QX6800 should be being read as 100c which would make coretemps temperatures correct..
Am no expert on those CPU's so might want to wait for advice from someone who is :)
40-50 on load is not bad at all, they could always be better, but most certainly nothing to worry about.
