Hi
May I get some advise on the components I have selected below to cool my CPU (I5 3750K), motherboard bridge (part of asus MB) and GPU (690gtx).
Have I got everything, is there anything I can take disregard or change?
Thanks BBr
EK-Supremacy Elite - CPU Waterblock - Intel 115x
EK Water Blocks EK-Coolstream RAD XTC 280EK Water Blocks
EK-CoolstreamRAD XTC 140
EK Water Blocks EK-FC690 GTX Backplate - Black
Mayhems Pastel - Blueberry Blue Coolant 1L x4
Bitspower Black Sparkle Y-Block Fitting With Triple Rotary G1/4" Ports
XSPC HighFlex Hose 1/2" ID, 3/4" OD, 19/12.7mm, 2m, Blue/UV Blue x3
Mayhems Fine Silver Kill Coil x2
Bitspower O-Ring Set - 50pcs - Black
EK PSC Compression Fitting 13mm 3/8" - G1/4 - Black x8
EK PSC Compression Fitting 13mm 3/8" - G1/4 - Black Nickel x5
Thanks BBr
