EDIT:
ALL DONE!!
take a look at the link for pics.
http://forums.overclockers.co.uk/showthread.php?t=17615297
is this the right order ? i bought a lot of the kit second hand so i have no instructions and since ive fitted it, im having some issues...
i ask because when i first turned it on, no liquid moved at all... i had to unhook one of the pipes and blow it through... now its flowing at about 65% capacity with LOTS of air in the tubes... any ideas ?
its a nexxos XP block
black ice pro radiator
some e-systems pump, not sure how to tell what model it is (its got quite a noisy grumble on it ? is that normal ? its quieter now some waters getting to it i will say)
its a half inch system... and a bloody huge difference when compaired to the thermaltake i threw out... its shaved 11oC of my idle cpu temp and im clocked even higher now
ALL DONE!!
