Is this voltage ok for DDR4
No fine. I run 1.75 on GSKILL and 1.6+ Kingston always fine. GSKILL since launch. Just bull as always.
Kaap how are you only coming to this article now? It's ancient.
If you bothered to read down you'd have read it's a VCCIN spike caused by an anomaly in the power up phase that was aggravated by a manufacturing defect. ASUS changed the power balancing for the board in UEFI 1004. The Deluxe has it's own unique VRM design so this board was the only one affected at the time.
The ICs have no problem with this voltage as neither do the boards, it's just the long term affects of running excessive voltage that is yet to be determined. As a gauge though I can't see there being any issues long term as long as kept in and around 1.6v. If you get a read on the module temperatures at these voltages, they barely exceed 40c.
Readings were taken whilst 2 hours into memtest @ 1.45v
We have determined the primary cause of failure for the pre-production ASUS X99 Deluxe you were testing on September 6, 2014 along with a secondary cause gathered during the investigation phase. Our initial analysis of the VRM Phase-4 MOSFET/Driver package failure is a bad solder point that was also present at the VRM Phase-3 location resulting in the failure you described along with the presence of solder balls. Additional analyses lead us to believe this was the secondary cause for the failure described.
After extensive testing and collaboration with leading power supply manufacturers and our VRM supplier (International Rectifier) it was determined that the new VRM design on the X99 Deluxe board needs a firmware update to balance start-up and shutdown power loads and sequencing across the MOSFET/Driver packages. We determined that higher loads were placed on the VRM Phase-4 package when the processor was drawing less than 70 amps of current during start-up and shutdown sequences based on the original firmware. This along with some older power supply OCP/Shutdown anomalies results in a bad component combination that randomly (very) leads to a VCCIN spike and power surge on the VRM Phase-4 MOSFET/Driver package that could cause component failures. We still have not replicated this failure in our test labs after thousands of hours of testing across a significant number of component combinations. However, we believe this was the primary cause for the initial board shutdown and the solder point issues exacerbated the subsequent component failures in the manner you outlined when using the secondary power supply. The good news is that we have a solution to this potential issue.
We are releasing a new EFI (build 1004) today that addresses this issue by balancing start-up and shutdown power loads across all VRM Phases when the processor is drawing less than 50 amps. This will greatly mitigate the chance of a VCCIN spike or power surge in rare instances based on extensive testing. Our new balancing/sequencing rules will decrease overall power efficiency results by a few percent based on processor loading under 50 amps but otherwise the board’s overall performance will not change. In addition to the new power rules, EFI release 1004 features a host of performance improvements with significant improvements in the area of memory overclocking using the 100 strap at speeds up to and past DDR4-3300.
We highly recommend that all users of the ASUS X99 Deluxe board download and install EFI 1004. This EFI is available from our support site starting today – X99-Deluxe EFI 1004. Please follow the proper instructions for updating your EFI. The update guidelines are available at ASUS USB BIOS Flashback Guide or follow the instructions in the user manual when utilizing USB BIOS Flashback or EZ Flash 2.
ASUS is firmly committed to supporting our class leading X99 Deluxe motherboard that features unmatched performance and options like our patent-pending OC Socket, 5-way Optimization for one click overclocking and fan control, 3×3 802.11ac, Fan Expert 3 and Crystal Sound 2.
Sincerely,
ASUS
Read more at http://www.legitreviews.com/intel-x...or-reasons-unknown_150008#25rLZT4T0t4ZuzVM.99
