Is USB 3 backwards compatible?
4 Dec 2009
Worcestershire
I thought I had read somewhere that USB 3 was backwards compatible but I can't remember if I actually did or not. Would a USB 2.0 memory stick for instance work in a USB 3 slot?
Thanks
yes USB 2 works in USB 3
Not always the case the other way around though, some USB 3 devices require the higher power output and hence don't work in some USB 2 ports. An example of this would be a USB 3 SSD drive I saw reviewed recently (recommended using the USB 3 -> 2 USB 2 adapter)
