Is vcore voltage fluctuation normal ??
29 Dec 2012
I have my vcore voltage set at 1.325 but it fluctuates between 1.320 - 1.344
yes,it goes to 1.344v due to loadline calibration,it bumps cpu v slightly to counter vdroop (cpu voltage drops slightly if under load)
what level llc vcore loadline calibration are you using? try low or medium can set a lower cpu voltage also
in the bios it should say vcore loadline calibration,its probably on auto and applying too much voltage,so try manually setting it to low or medium
yes medium is the first one i tried, is it ok if i leave it at auto the voltage only goes up much when it get stressed with prime or would it be best to set it manually.
