Isass.exe removal
24 Aug 2003
Warrington
Can anyone help My CPU is running at 100% for 2 seconds then 0 for 2 seconds. When I look at the processes in taskmanager Isass.exe is up & down as discribed. I have looked on the web to no avail. I think it is a trojan.
*2nd search result on google =
Windows errors related to isass.exe ?
isass.exe is registered as the Optix.Pro virus which carries in it's payload, the ability to disable firewalls and local security protections, and a backdoor capability
(The powers of search are weak in you my son)
Turn off system restore, Put your system in safe mode then run Ad aware & then your AV.
