I’ve been trying to separate out my iSCSI traffic on my NetApp san, but I’m having problems when I want to have a windows host that has a Nic for iSCSI and a Nic for normal network traffic and was hoping someone might be able to point me in the right direction.
Currently I have my SAN’s iSCSI Nic plugged into a separate switch which isn’t connected to the rest of the Network. My windows host has one nic plugged directly into this switch and the other plugged into the rest of the network
iSCSI Nic on windows host is set up 10.10.20.167/255.255.252.0 – Default Gateway 10.10.20.1
Network Nic on windows host is set up 10.10.20.67/255.255.252.0 – Default Gateway 10.10.20.1
When I enable the iSCSI Nic it connects to the filer fine, but I am no longer able to connect to the server via the Network.
Is there something in addition that I should be setting on the Nics or do I need to use a different subnet and IP Range for the iSCSI Nic on the filer and the host.
Thanks
Thanks
