- 22 Aug 2010
- In My Command Center
i have an i7 2600k @4.8ghz oc at 1.34/5volts which turns out to be not as stable as i first thought!
3hrs into another prime and it bsod'd me 101 = more vcore! i upped the volts to 1.36 and i have done the four hour mark fine! i acually got to 6 hrs before i thought enough is enough and my temps were 53-56-53-53 just before i stopped
i decided to see what 4.7ghz would produce in contrast and i run 4 hours prime stable @1.328volts as i type, temps 53-58-56-56???????
the only way i can get 5ghz stable is by going to 1.44volts! the jumps are huge?!?
i doubt i will see any difference if i juiced up my chip for .1ghz!
i have done a lot of reading on many forums and it seems a lot of people have been running 1.4volts+ 24/7 with good cooling but when i tested crysis for fps using my 5ghz set up and my 4.7ghz setup there were 6fps difference.
i dont think its worth it imo
