Hi all. Been thinking about this since this morning.
I have fitted the ISO fix for our babies car seat (baby due January). It all fits well except there is a space between the seat and the bottom of the ISO fix. Basically the front leg of the ISO fix has been extended quite high as this makes the fitting quite rigid which I'm sure is how it should be, however extending the leg this high creates the empty space. Is this right? Surely not?
We're using the maxi cosi ISO fix with the maxi cosi pebble seat if that helps and it's currently fitted into a Peugeot 206 verve which will be traded in for something bigger in the new year.
Any help much appreciated
