ISP for Gaming. ADSL only
Status
Not open for further replies.
30 Jun 2004
I am in need of finding a new ISP for gaming.
Currently I use IDNET but have been constantly pinging 120+ on week nights when playing for the last 2 weeks. Used to ping about 45-50. IDNET cannot provide a reasoning behind it. So looks like it might be time to change.
Can anyone recommend a new ISP specifically for low pings.
Location is PE31 - Hillington Exchange.
Many Thanks,
Chef
If you don't need a high data allowance (and if it's just for mostly gaming and the odd patch) then Zen would be my choice.
I would suggest skys normal connection, not the LLU, as ofcourse no LLU available.
The reason i suggest sky is that even on there normal package they will offer to reduce your delays if you are a gamer, take alook over at skyuser.co.uk.
They don't advertise this but will do it if you call them, worth a look at in my opinion.
Indeed as Above Zen would probably be my choice for simply gaming. Their low usage allowance forced me to move away though, but Ive never had pings lower than when I was connected via them.
Status
