Hi All i,m after a some info regarding my ADSL I was told in an email by Be Unlimited that i should set these setting to improve a speed issue,what i want to know is are they worth doing or need doing ? any help feedback please thanks
the settings are below:
1 .
Please go to the Network connections and mark the Local Area Connection, right click, Properties: In the General menu hit Configure (that will take you to the setup of your Lan card). Go to Advanced/ Speed&Duplex - the Value should be 100Mb Full.
2.
Please check your LAN card settings and adjust them for performance to throughput instead of CPU.I am not sure but i take it means to enable it as it is set to disabled at present ?
the settings are below:1 .
2.
