- 11 Oct 2005
- Derbyshire
Hi. Curious to know the answer.
Most isp’s supply a router. I have a black one from sky. Which works fine. Can connect all my WiFi devices to it and it is also connected to a network switch. For other hard wired devices.
But I’m curious what the other routers that you can go out and buy do.
Is it just a replacement. Or something else?
Thank you
Thank you
