iSSLfix Jailbreak Tweak Repairs SSL Vulnerability On iOS 4.3.3
Man of Honour
20 Sep 2006
I'm not sure if I can link but I'll copy and paste.
The security issue on pre-4.3.5 devices is an SSL vulnerability known as "CVE-2011-0228", and luckily for those of you that don’t fancy getting caught in the dire straits of tethered jailbreaking, there is a simple solution on hand to fix the issue.
iSSLfix, which is available in Cydia, will bring your device’s security level on par with iOS 4.3.5 without the need to update. It can be found on the BigBoss repo, which you will already have installed on your source list unless you’ve deleted it. You will have to momentarily change your file view settings to Expert if you are currently on Simple in order to locate the file in a search. This can be done by going to Manage > Packages, and tapping the Simple button in the top right-hand corner, which will expose the "Expert" files within Cydia.
