Hi,
I need some help. I'm having major issues trying to install the Nvidia drivers for my RTX3090 GPU. When I try to install the Nvidia driver my PC crashes and attempts to reboot, eventually ending up at the blue WIN 11 screen.
My build:
Mobo: ASUS ROG STRIX Z790-A Gaming WIFI (the DDR5 variant)
CPU: Intel i5-13600K
RAM: 64GB (2x 32GB) Corsair Vengance - 5600
Storage (M2.1 slot): Samsung SSD 980 Pro 2TB - the OS is here
Storage (M2.2 slot): Samsung SSD 980 Pro 2TB
PSU: ASUS Thor 850W Platinum II
New GPU: Gigabyte Aorus RTX3090 Waterforce extreme WB rev.1 (note: card is mounted upright)
Old GPU: MSI Ventus 1660 with Byski waterblock - works fine
Cooling: is custom hard-tube water-cooled, (note: GPU card is mounted upright)
OS: WIN11
This is what I've tried so far:
Some other useful info: I have also tried Gigabyte Aorus RTX3080 Waterforce extreme WB rev.1 - same issue.
Any suggestions?
My build:
OS: WIN11
- Updated the drivers the usual way, uninstalling everything Nvidia, and installing the card - didn't work: crashed during installation and eventually end up on the blue screen.
- Loading up in safe mode, using DDU to remove everything relating to the GPU, then installing the nVidia drivers in safe mode, versions: 472.12, 496.13, and 536.40. All install fine in safe mode, but crash on reboot, eventually ending up on the blue screen.
- I've tried the above with BIOS version 1001 and 1201 on the mobo, same issue.
Any suggestions?
