Hi Guys, after a little help if you can.
I bought a new 4670k and a Z87X-UD3H the other day, installed it fine, only problem during installation was the processor gate was a bit tight to close but works fine first power on. I have 16gb of Crucial Ballistix 1866 memory (the ones with the LEDs) and a Windforce 7950 in it also that come from my old rig that work fine.
The problem I have is every other power on it fails to start, with dual bios enabled it cycles on and off on and off in a loop. I turn it off a few times and it works.
If I put it in single bios mode it shows error code 15 (Pre-memory North Bridge initialization is started) and hangs there without the memory leds lighting up. power on off a few times and it works.
I've tried putting just one memory stick in, in every slot, same result.
I've upgraded the bios to F7, no difference.
I'm using the machine now and when its booted its fine, been playing BF4 beta
Any clues?
Any clues?
