Hi guys.
Was hoping you'd be able to help me out with something. I recently built my first pc. 6700k on asus pro gaming z170 mobo and it all went fine. I was using my old radeon 6970 ice q.
However today my zotac 1070 amp extreme arrived along with a Dell s271dg. At first I wasn't sure what cables to use as the zotac need 2x 8. My psu is the evga 650w g2 and came with two cables that were 8 on one side and a 6 and 6+2 on the other side. I've plugged two of those into the card, the 8 on to the psu and the 6+2 in to the card. When I switch it in the green light comes up above the power on the card and the leds on the cards light up too.
However it makes an awful racket like the fans are rattling with plastic inside of them almost. And it doesn't pick up the monitor at all through the dp cable. I manged to get on by plugging the monitor into usb and in the device manager the graphics card doesn't appear.
One last point is that I had to plug the card into the second pci express slot on the mobo as the USB cable blocks the top one.
Any help would be greatly appreciated
Cheers
Cheers
