- 26 Mar 2009
- Ashington , N/land UK
Morning,
Recently had water pump go on my Coolit domino..so got the replacement and unplugged everything then put everything back together and powered up...no monitor...unplugged graph card , checked power etc etc etc ..and eventually got the screen back on by wiggling the HDMI cable at the back off the monitor...although the colours at boot up seemed a bit odd (the windows 7 logo had red pixelations arround it..)
So unplugged the cable and checked it /tried another cable..same issue..
Cables look perfectly normal..
checked inside the port and noticed that the hdmi port looks a bit off...the plastic bit in the middle is not straight and as a result some of the copper strands are not in the correct place....
The card is 1 year old in October....but before I raise an RMA with OC...what are my chances..or am i looking at using another off the ports ( which is a shame as just convinced the misses that a second 24 inch monitor would help her eye sight)
I never noticed this when installing the card, but then i had gleefully just taken delivery off the card so never gave the card a full inspection..
I can not see anything that would cause the HDMI port to deform like that (the hdmi cable is perfectly true and works perfectly with other hdmi equipment)..
Thoughts...
Regards
Ray
Thoughts...
Regards
Ray
