Issue with new 3900x build
27 Aug 2004
I have recently built a new pc with the specs below:
  • AMD Ryzen 3900x
  • Gigabyte Aorus Pro X570
  • Gigabyte Aorus 1tb Pcie 4 NVME M.2
  • Corsair Vengenace LPX 32 Gb PC4-28800
  • Bequiet Dark Power Pro 10 650w
  • Asus Strix RTX 2070 Super
  • Segate 2TB Sata HD
  • Bluray reader Sata
Other than the SATA issue that I am about to explain the system seems to be running ok. I have checked the SSD in Crystal Disk mark and it is hitting the figures shown in the reviews.
The issue I am having is that when plug in the Seagate drive which is just for data storage. If I then look at the system log in Windows I get lots of errors similar to those below and it also doesn't even recognise the optical drive in the BIOS or Windows. All the messages in Event Viewer are Yellow Warnings. I have got version F11 of the BIOS installed. I did have a look at the SATA options in the BIOS and the only choice seems to be AHCI or RAID, the former should be ok and is what it is using.
The last error below may be unrelated as I am not using RAID and have the drive in SATA port 0.
I have also put my old intel system back together outside of the case and both the hard drive and optical drive work without issue.
I have also tried different SATA cables and sockets.
Event ID: 153 Source: System
The IO operation at logical block address 0x5caec8 for Disk 0 (PDO name: \Device\00000041) was retried.
Event ID: 140 Source: Ntfs (Microsoft-Windows-Ntfs)
The system failed to flush data to the transaction log. Corruption may occur in VolumeId: D:, DeviceName: \Device\HarddiskVolume6.
(The I/O device reported an I/O error.)
Event ID: 129 Source: System
Reset to device, \Device\RaidPort3, was issued.
Yes on both counts. It was fresh install of Windows 10 1909 on the NVME drive which is new. The storage drive was just moved from the old pc. It does show up in Windows and gets assigned a drive letter. But any combination the optical drive does not show in the BIOS or Windows.
I have also just had another look through the BIOS to see if anything is set wrong and came across the ones below:
SATA Configuration:
SATA Mode = AHCI
Chipset SATA Port Enable = Enabled
Chipset SATA Hot Plug = Enabled
Boot page:
CSM Support = Enabled
Looks like it was either a BIOS issue or XMP profile related. As last night I upgraded the BIOS from F11 to F12e and I can now see the optical drive and no longer get any errors about the seagate drive. I will be trying XMP again later.
Nice one, sorry for forgetting to reply back .
Any issues, hopefully @GIGA-Man can see if they have been mentioned but globally staff at vendors are working at reduced/difficult rates .
