Looking for some help and advice here. The father-in-law's PC stopped working last night. It's been working fine for around a year since I upgraded CPU, motherboard and RAM (Asus Z170, i5 CPU). He's claiming (and I'm not sure I believe this) that there was a lot of crackling noise last night then it wouldn't power on. The issue is that the noise came from near the monitor which is on the desk, the case is on the floor.....
Basically the PC does not POST. You can see that the board is getting power as the LED's on the board are lit. When you push the power button, the fans (CPU, Case and PSU) spin for a second and then stop for a couple, then spin up again for a second and stop etc etc etc (the Power button light flashes in sync with the fans).
I've tried resetting the BIOS by removing CMOS battery and shorting the required jumpers. I've re-seated all power connections and checked all others. I've disconnected everything (RAM, DVD drive, HDD's), but still the same.
I'm thinking it may be a PSU issue as that's an old OCZ (with only a 4 pin ATX connector) that I used for his original PC build a good few years ago.
What does anyone think ?
