- 24 Jan 2022
- Greece
Hello guys I have had my desktop built some months ago. I have an issue with my graphics and games feel slightly delayed and not synced. This affects everyday usage aswell as gaming. My Specs:
CPU: Ryzen 7 3700 X, MOBO: B 550 TOMAHAWK , GPU: 3060 TI , RAM : 32 GB 3200 MHZ Ripjaws Gskill ,SSD: 1TB NVME Kingston A 2000, PSU: 750 W gold rated Coolermaster. I have changed my monitor the GPU, PSU got my MoBo RMA'd . This leaves the CPU as the main suspect, which is rare from what I heard but could make sense. Windows 10 and 11 have been tried out issue persists , all drivers up to date and benchmarks for all components are fine. Besides the CPU ( CPU temps are fine) , the only things I have not swapped out is the RAM and the NVME but my ram poassed memtest 86 adn windows diagnostics. My B 550 got replaced with a new one after RMA my old one so there is a slight chance this MOBO has issues with my components in general. What would you do? Note: I use a 144 HZ display . refresh rate is set correctly and tweo monitors have been tested
