Hey,
I'm having some serious issues overclocking my 3800x2 on my asrock dual sata II.
For some reason I can't take the FSB above 220 otherwise the system just resets. The memory is rated 3,4,4,8 (its OCZ value 2 gig). I have it running it 3,4,4,10 and set to 166 (rated to 200) [2T]. I have the HSF? set to 600mhz / 16bit and ram voltage is set to high (which im led to believe is 2.7 volts on this board) and the cpu volts are set to the max for this board 1.4Vlts.
If I set the mobo to Flexibility mode I can take the chip up to 2.5Ghz (orthos stable but its still crashes sometimes .. annoying). I don't like setting this mode though as it really limits to memory speed.
Any ideas
Andy
Any ideas
Andy
