- 19 Oct 2011
First of all here is my current system:
Motherboard: Asus Sabertooth P67 B3 Rev
CPU: Core i5 2500K
CPU Cooler: Corsair Hydro H60
Memory: Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz
PSU: Coolermaster Silent Pro 1000W
Graphics: MSI GeForce GTX 580 OC Twin FrozR II 1536MB
Sound Card: Asus Xonar D2X 7.1
HDD: OCZ Agility 3 120Gig
Case: Coolermaster HAF 912
Now after so much reading, advice from here and several websites and forums I've tried OC my 2500K however to no avail.
I think it's a voltage issue but I'll explain. After changing all the settings in the Bios but using the overvolt + system for the voltage the system booted but CPU-Z registered a voltage of 1.34V on a 4.5Ghz clock.
So I decided to set the voltage mYself as Ive read anything over 1.3V is bad for the CPU. So I went for 1.27V. The system wouldnt boot into windows and blue screened at the windows logo.
So I changed to 1.28V. The system booted to windows but the when I loaded CPU-Z it blue screened so I went for 1.29V.
The system booted and everything seemed stable. I ran CPU-Z to ensure OC was at 4.5Ghz and CPU-Hardware Monitor to check temps and ran Prime 95 for stability. After 8 passes with CPU temps as follows
CPU 0: 64 Degrees
CPU 1: 66 Degrees
CPU 2: 65 Degrees
CPU 3: 67 Degrees
CPU Overall: 66 Degrees
The system bluescreened again
Changed the voltage to 1.295V same issue and so Ive now given up. Can anyone help me pleeeeeaaaaasssseeee
Ive heard that not all 2500K's can be overclocked. Am I just unlucky?
CPU: Core i5 2500K
CPU 0: 64 Degrees
CPU 1: 66 Degrees
CPU 2: 65 Degrees
CPU 3: 67 Degrees
Just keep the temps in check.
