Issues playing a DVD in my ps3
12 Oct 2003
B'ham
Hi,
Just been trying to play a DVD in my ps3 but when I pop it in I get a little loading circle in the top right hand corner, but then shortly after I get the "No Signal" message being displayed on my screen. To get it back I have to switch off the ps3 and back on.
I have done a bit of googling on this and read that I needed to switch 24 fps playback to off from automatic which I have done but I am still getting the same problems.
Thanks
PS I have tried a couple of dvds, Blu-Rays however play perfectly fine.
Ok i had this problem its not a fault with the PS3 ie its not broken, its a setting in the DVD playback options. Will try to remember what it was, but i found out how to sort it on the EU PS3 forum.
I managed to sort it, I just messed around with a few settings in the BD/DVD menu and also system settings where I changed the display from 1080i to 720p. Don't know which one actually made it work in the end but just keep changing the settings until it works.
