I upgraded my main PC at home to the new 6.22 beta2 SMP client yesterday as it had recentally finished a WU, so I thought it would be a good time.
I stopped both current SMP clients from running, made sure all their cores were killed off, restarted the computer, deleted all the old files then installed the new client. Everything seemed to go OK and I got both clients up and running again.
Fast forward to this morning and neither client has even done 1% of its processing so I start to get suspicious. I killed off both clients again and started runnign just a single SMP instance and within 30 minutes it had finished off 2% of the core.
Anyone got any idea why this might be happening ? (BTW this is still with 2 GPU clients going as well)
Presumably you're on a quad core, in which case you would be trying to run 2 SMP clients on essentially 2 cores (if you're on XP the GPUs use one core each). I would leave it running with just one SMP client for now and see what your PPD is.
) then the SMP clients will have less CPU to work with.
