- 2 Mar 2013
This is the first time I've upgraded my own rig with the idea of tweaking it for greater performance. As budget is limited I went for AMD FX 6200, ASrock 990fx extreme 3 Mobo, 8 gigs of patriot 1600 ram to add into my CM storm scout case, hard drives and TX650 PSU. Now the kicker is I went for the CM siedon 120M AIO water cooler. In retrospect, this was the wrong choice but I was interested to see what I could do with it and added an extra fan for push pull config.
What I have found is even at stock 3.8Mhz the CPU is thermal throttling down at 52 degrees which it is hitting pretty quickly when I stress test on Prime95. So really, from what I can see, the cooler is not adequate.
Is there anything else I should be looking at?
