Issues with Asus DSL-N55U
30 Jul 2007
Lincolnshire
So I'm having issues with my Asus DSL-N55U ADSL2+ Modem/Router I bought at the beginning of this month. I had similar issues previously, but my family members seem to complain about the wireless constantly dropping out and not letting them reconnect. In the end it either reconnects after 5 minutes, or with enough playing disabling & re-enabling the wireless adapter it works.
I have noticed in the System Log of the router hundreds of lines of this 'not enough space in MgmtRing' error. It has been there since day 1. I raised it with Asus' "tech support" within 3 days of installing the router. There instant response was the below, very un-informative and gave me no possible resolution or reason whatsoever..
Tbh the 5GHz band of the WiFi seems fine. Just the 2.4GHz band. I've tried changing the wireless channel, running inSSDier to see what channel is being used the most (1, 6 and 11) tried all 3 plus ones that are further away from this to even 'avoid' interference but it achieves nothing. It could well be a faulty unit, I'm just struggling to see how/why! I am using WPA2-Personal security.
I've tried re-flashing the latest firmware 2/3x, restoring to factory settings, etc. But still no dice!
Hoping someone has some advice/tips.. Or if I should just get a full refund and put back in my Netgear DG834GT which performed no worse than this! :rolleyes:
Joe from Asus 'Tech Support' said:
Dear Valued Customer,
Thank you for contacting ASUS Customer Service.
My name is Joe and it's my pleasure to help you with your problem.
This may be the hardware issue.I suggest you may ask your retailer to exchange a new one.
If you continue to experience issues in the future, please do not hesitate
to contact us.
Best Regard
Joe
Code:
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=1!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=2!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=3!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=4!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=5!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=6!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=7!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=8!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=9!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=10!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=11!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=12!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=13!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=14!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=15!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=16!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=17!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=18!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=19!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=26!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=27!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=28!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=29!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=30!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=31!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=32!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=33!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=34!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=35!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=42!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=43!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=44!
Dec 17 21:39:32 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=45!
Found this too in my log, not sure if it means anything..
Code:
Dec 17 21:39:09 kernel: Channel 1 : Dirty = 350, False CCA = 45, Busy Time = 4386, Skip Channel = FALSE
Dec 17 21:39:09 kernel: Channel 2 : Dirty = 180, False CCA = 73, Busy Time = 5529, Skip Channel = FALSE
Dec 17 21:39:09 kernel: Channel 3 : Dirty = 164, False CCA = 8, Busy Time = 1003, Skip Channel = FALSE
Dec 17 21:39:09 kernel: Channel 4 : Dirty = 148, False CCA = 22, Busy Time = 657, Skip Channel = FALSE
Dec 17 21:39:09 kernel: Channel 5 : Dirty = 132, False CCA = 61, Busy Time = 1596, Skip Channel = FALSE
Dec 17 21:39:10 kernel: Channel 6 : Dirty = 110, False CCA = 54, Busy Time = 4106, Skip Channel = FALSE
Dec 17 21:39:10 kernel: Channel 7 : Dirty = 80, False CCA = 52, Busy Time = 1006, Skip Channel = FALSE
Dec 17 21:39:10 kernel: Channel 8 : Dirty = 84, False CCA = 39, Busy Time = 2653, Skip Channel = FALSE
Dec 17 21:39:10 kernel: Channel 9 : Dirty = 88, False CCA = 280, Busy Time = 11674, Skip Channel = FALSE
Dec 17 21:39:10 kernel: Channel 10 : Dirty = 160, False CCA = 100, Busy Time = 13165, Skip Channel = FALSE
Dec 17 21:39:10 kernel: Channel 11 : Dirty = 64, False CCA = 239, Busy Time = 24146, Skip Channel = FALSE
Dec 17 21:39:10 kernel: Channel 12 : Dirty = 56, False CCA = 194, Busy Time = 11812, Skip Channel = FALSE
Dec 17 21:39:10 kernel: Channel 13 : Dirty = 48, False CCA = 18, Busy Time = 1500, Skip Channel = FALSE
Dec 17 21:39:10 kernel: =====================================================
Dec 17 21:39:10 kernel: Rule 1 CCA value : Min Dirtiness (Include extension channel) ==> Select Channel 13
Dec 17 21:39:10 kernel: Min Dirty = 4294967295
Dec 17 21:39:10 kernel: ExChannel = 0 , 0
Dec 17 21:39:10 kernel: BW        = 20
Is the bottom log from the wireless log tab?
Nope, that was just a little further up from the 1st quote from the System Log.
Sounds faulty to me, get it exchanged :)
Yeah seems faulty, get it replaced.
So everyone agrees with ASUS? Just to replace it, no possible solutions, fixes or what it might be? :p
EDIT: Not sure if I should get a replacement or just get it refunded and go back to my DG834GT. Performance wise I couldn't even tell the difference..
EDIT2: Just had a look at my router's System log today and I have no errors apart from this one:
Code:
Dec 18 15:29:16 kernel: Replay Counter Different in pairwise msg 2 of 4-way handshake!
I've got some similar error messages and similar complaints, seems like it might be some sort of wireless incompatability from my searching it only seems to happen when there are a lot of devices on the router.
If I was able to I'd get each person to disable there device to isolate it although it's not very practical as I'm in a shared house and not everyone is on at the same time.
There is some new beta firmware which has a new 2.4Ghz firmware in it, although I'm not sure it'll solve the problem https://www.asuswebstorage.com/navigate/s/9628502F203846C5956A0DE29AB220ADY
Look on the Asus forums for more info.
Can't seem to find the ASUS forum discussing this BETA firmware you've linked me to (3.0.0.4.317). I'll download it though and give it a go tomorrow maybe.
But saying that, tonight nearly 11pm and all day I have just had the below in my router's Sys Log. Not a peep from the above errors I posted!
Code:
Dec 18 19:23:57 kernel: Replay Counter Different in pairwise msg 2 of 4-way handshake!
Dec 18 22:16:34 kernel: Replay Counter Different in pairwise msg 2 of 4-way handshake!
Firmware bugs, I'm using 317 beta now. All seems fine.
It's a good router, just a shame that Asus use their customers to do the testing of the firmware!
Almost reached the perfect firmware release, they're working on it very quickly, any problems you have, post them in the Asus forum.
I also recently purchased the N55U and have been having the exact same problems, after posting on their support forum as recommended that I upgrade to firmware version 317 as this contains new device drivers. Since doing this logs have been pretty much free of these error messages.
Stability is also MUCH better now.
So after another 24 hours, my System Log was actually empty! No errors at all. But still I upgraded the firmware to this beta 317. It's made the errors worse! Although I haven't been home this evening to see how the Wireless has been. Generally browsing on my laptop now on the 5GHz band it seems quick though despite the errors, more responsive, etc.
See below - ridiculous!! I still see the odd 'not enough space in Mgmtring' error in between all of this..
Code:
Dec 19 18:02:34 rc_service: ntp 657:notify_rc restart_upnp
Dec 19 18:13:30 kernel: Received RSNIE in Assoc-Req: c0156cdf, len = 24
Dec 19 18:13:30 kernel: 0x0000 : 30 16 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 19 18:13:30 kernel: 0x0010 : 00 0f ac 02 3c 00 00 00
Dec 19 18:13:31 kernel: PMK: c0136261, len = 32
Dec 19 18:13:31 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 19 18:13:31 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 19 18:13:31 kernel: concatenation=: 802c1b08, len = 76
Dec 19 18:13:31 kernel: 0x0000 : 00 1f 3c 08 40 18 10 bf 48 81 b5 68 17 f6 c3 45
Dec 19 18:13:31 kernel: 0x0010 : 81 9d a5 63 21 b9 19 4d 91 11 1f 7d 18 d7 5d 49
Dec 19 18:13:31 kernel: 0x0020 : 08 6d 1d 64 aa 4f 21 46 5b 74 5f e6 53 b8 ae 88
Dec 19 18:13:31 kernel: 0x0030 : f6 4d 1a ef 2f 63 50 9e 59 5e 36 1f ec eb 0e 0d
Dec 19 18:13:31 kernel: 0x0040 : a0 dd 97 5a 09 a1 be 37 aa 3f 99 45
Dec 19 18:13:31 kernel: Received RSNIE in Assoc-Req: c01519cb, len = 22
Dec 19 18:13:31 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 19 18:13:31 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 19 18:13:32 kernel: PMK: c0136261, len = 32
Dec 19 18:13:32 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 19 18:13:32 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 19 18:13:32 kernel: concatenation=: 802c1b08, len = 76
Dec 19 18:13:32 kernel: 0x0000 : 00 1c df 30 f4 cd 10 bf 48 81 b5 68 27 d7 84 cb
Dec 19 18:13:32 kernel: 0x0010 : 64 ca b8 99 46 34 b8 4e 98 74 59 ec c2 a4 9b c5
Dec 19 18:13:32 kernel: 0x0020 : 8f 5f 5b a1 b5 a4 7b 7c 75 f3 b6 5b e5 c1 90 66
Dec 19 18:13:32 kernel: 0x0030 : 4f 89 1e 85 28 3d 5b 2d fa 29 e9 64 5c e0 0a b2
Dec 19 18:13:32 kernel: 0x0040 : 15 7e d1 e6 bf 97 a9 16 55 94 6c 23
Dec 19 18:16:37 kernel: Received RSNIE in Assoc-Req: c014f349, len = 22
Dec 19 18:16:37 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 19 18:16:37 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 19 18:16:38 kernel: PMK: c0136261, len = 32
Dec 19 18:16:38 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 19 18:16:38 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 19 18:16:38 kernel: concatenation=: 802c1ad8, len = 76
Dec 19 18:16:38 kernel: 0x0000 : 10 bf 48 81 b5 68 a0 f4 50 b6 07 31 08 96 fd c4
Dec 19 18:16:38 kernel: 0x0010 : a2 31 50 37 a9 b9 01 1a fd 6a 0f a1 1a 93 f8 8b
Dec 19 18:16:38 kernel: 0x0020 : 62 5d 15 ff a9 83 c4 70 3b b4 69 0f be f6 d1 c4
Dec 19 18:16:38 kernel: 0x0030 : 37 80 43 b2 70 df d2 ea 03 10 1e b7 56 76 34 12
Dec 19 18:16:38 kernel: 0x0040 : 83 64 c0 ce 72 8a 8f e2 34 3c 68 31
Dec 19 18:16:41 kernel: RTMP_TimerListAdd: add timer obj c01c23a4!
Dec 19 18:34:51 kernel: ERROR!!! RTMPCancelTimer failed, Timer hasn't been initialize!
Dec 19 18:34:51 kernel: RTMP_TimerListAdd: add timer obj c0198628!
Dec 19 18:34:51 kernel: RTMP_TimerListAdd: add timer obj c01987dc!
Dec 19 18:34:51 kernel: Received RSNIE in Assoc-Req: c014f98f, len = 22
Dec 19 18:34:51 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 19 18:34:51 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 19 18:34:52 kernel: PMK: c0136261, len = 32
Dec 19 18:34:52 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 19 18:34:52 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 19 18:34:52 kernel: concatenation=: 802c1b08, len = 76
Dec 19 18:34:52 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 7f 1d 07 14
Dec 19 18:34:52 kernel: 0x0010 : 8e bb 75 d9 51 33 89 9c b3 1c 31 cb 8e 5a 8d 2b
Dec 19 18:34:52 kernel: 0x0020 : 69 58 4a c1 53 e0 9f 00 f8 07 c0 3b a1 00 7b 03
Dec 19 18:34:52 kernel: 0x0030 : ea 63 c6 56 b8 75 29 d0 96 a2 61 d6 a2 79 85 c3
Dec 19 18:34:52 kernel: 0x0040 : c7 ae bf 56 6e 23 71 3a 58 27 52 a9
Dec 19 18:35:10 kernel: RTMP_TimerListAdd: add timer obj c01c23f0!
Dec 19 18:35:35 kernel: RTMP_TimerListAdd: add timer obj c01beb90!
Dec 19 18:43:39 kernel: Received RSNIE in Assoc-Req: c014f98f, len = 22
Dec 19 18:43:39 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 19 18:43:39 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 19 18:43:40 kernel: PMK: c0136261, len = 32
Dec 19 18:43:40 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 19 18:43:40 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 19 18:43:40 kernel: concatenation=: 802c1b08, len = 76
Dec 19 18:43:40 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 99 7a aa 9d
Dec 19 18:43:40 kernel: 0x0010 : 3e 2d f0 6d 94 73 f7 2c e2 38 01 77 fb f9 3d 51
Dec 19 18:43:40 kernel: 0x0020 : fd 49 80 70 4a 89 14 94 5e 94 a4 89 a4 c8 d9 bd
Dec 19 18:43:40 kernel: 0x0030 : 64 2f de 86 17 91 bc 8e e4 73 b8 cf 39 80 98 0b
Dec 19 18:43:40 kernel: 0x0040 : c0 58 02 c0 2c 0c 60 65 f9 a2 cd 12
Dec 19 18:44:55 kernel: RTMP_TimerListAdd: add timer obj c01bebc8!
Dec 19 19:04:51 kernel: ERROR!!! RTMPCancelTimer failed, Timer hasn't been initialize!
Dec 19 19:04:51 kernel: RTMP_TimerListAdd: add timer obj c0199088!
Dec 19 19:04:51 kernel: RTMP_TimerListAdd: add timer obj c019923c!
Dec 19 19:15:14 kernel: Received RSNIE in Assoc-Req: c01559ad, len = 22
Dec 19 19:15:14 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 19 19:15:14 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 19 19:15:16 kernel: PMK: c0136261, len = 32
Dec 19 19:15:16 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 19 19:15:16 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 19 19:15:16 kernel: concatenation=: 802c1b08, len = 76
Dec 19 19:15:16 kernel: 0x0000 : 10 bf 48 81 b5 68 18 87 96 8f a1 f1 4a 64 99 c8
Dec 19 19:15:16 kernel: 0x0010 : 37 e3 71 52 f7 1c 9a d5 a7 6e a8 a8 f2 8a 02 93
Dec 19 19:15:16 kernel: 0x0020 : 80 1e 53 3d 54 99 ef 4a fa d8 28 de d8 7d bb fb
Dec 19 19:15:16 kernel: 0x0030 : 8e 58 db 1e 28 bc 4d fd 8a f2 45 43 53 36 a1 d0
Dec 19 19:15:16 kernel: 0x0040 : 0c 60 26 09 3e 21 b1 12 5e fe f9 fd
Dec 19 19:20:53 kernel: Received RSNIE in Assoc-Req: c0152ccf, len = 22
Dec 19 19:20:53 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 19 19:20:53 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 19 19:20:53 kernel: PMK: c0136261, len = 32
Dec 19 19:20:53 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 19 19:20:53 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 19 19:20:53 kernel: concatenation=: 802c1b08, len = 76
Dec 19 19:20:53 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 2d 23 69 1a
Dec 19 19:20:53 kernel: 0x0010 : 48 d6 46 b7 35 b8 a4 72 23 90 1c 87 1b c3 de 18
Dec 19 19:20:53 kernel: 0x0020 : 1e 74 f3 a0 9d 01 17 f4 40 59 fa 6a 3a 03 c6 ba
Dec 19 19:20:53 kernel: 0x0030 : 68 8e 2c b8 76 99 e9 6b e1 1b 2f 3e f8 62 c7 04
Dec 19 19:20:53 kernel: 0x0040 : de 32 40 c0 99 6e 48 2a 0e c0 4a 9b
Dec 19 19:36:28 kernel: Received RSNIE in Assoc-Req: c015399f, len = 22
Dec 19 19:36:28 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 19 19:36:28 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 19 19:36:28 kernel: PMK: c0136261, len = 32
Dec 19 19:36:28 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 19 19:36:28 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 19 19:36:28 kernel: concatenation=: 802c1b08, len = 76
Dec 19 19:36:28 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 69 f0 9f 0b
Dec 19 19:36:28 kernel: 0x0010 : f8 58 3d 3e 16 0d 4f 90 06 fe c8 08 bf ba 02 28
Dec 19 19:36:28 kernel: 0x0020 : ee b9 14 6e 5c 8d 1b 93 dc 98 1b 38 6f 3b f7 c5
Dec 19 19:36:28 kernel: 0x0030 : 6a 92 f2 98 5c f1 b2 00 b2 fe 73 da fb fa b8 18
Dec 19 19:36:28 kernel: 0x0040 : 42 32 db c4 69 a8 c2 19 8c 76 6d 4a
Dec 19 21:24:53 kernel: Received RSNIE in Assoc-Req: c0150cc7, len = 22
Dec 19 21:24:53 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 19 21:24:53 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 19 21:24:53 kernel: PMK: c0136261, len = 32
Dec 19 21:24:53 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 19 21:24:53 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 19 21:24:53 kernel: concatenation=: 802c1ad8, len = 76
Dec 19 21:24:53 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 1b bc 26 0d
Dec 19 21:24:53 kernel: 0x0010 : 6a 16 d6 78 04 48 29 35 60 1f 92 f6 b4 dd c0 1c
Dec 19 21:24:53 kernel: 0x0020 : 8c 1b df 81 db bd 10 80 3c 59 8d f1 60 dd f2 20
Dec 19 21:24:53 kernel: 0x0030 : 91 00 10 05 00 5e 05 eb 2f 58 f5 83 58 36 c1 b0
Dec 19 21:24:53 kernel: 0x0040 : 0d 80 d8 01 7f e4 00 db 06 d9 6d 93
Dec 19 21:25:22 kernel: Received RSNIE in Assoc-Req: c0151fff, len = 22
Dec 19 21:25:22 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 19 21:25:22 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 19 21:25:22 kernel: PMK: c0136261, len = 32
Dec 19 21:25:22 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 19 21:25:22 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 19 21:25:22 kernel: concatenation=: 802c1ad8, len = 76
Dec 19 21:25:22 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 ab cd 5e 69
Dec 19 21:25:22 kernel: 0x0010 : 19 64 69 bb 9b bc dd e0 de 0f 1f 0b 0f 43 7a 1d
Dec 19 21:25:22 kernel: 0x0020 : a1 db 1d bd 24 2d 21 6e e9 11 6e e6 c8 ed b8 3e
Dec 19 21:25:22 kernel: 0x0030 : e9 8e 9d 85 94 c7 00 62 ac 97 e4 b0 1c 36 1e 09
Dec 19 21:25:22 kernel: 0x0040 : 75 f7 cb c7 34 30 9a 3f 9a 1a f8 0e
Dec 19 21:32:00 kernel: Received RSNIE in Assoc-Req: c0151997, len = 22
Dec 19 21:32:00 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 19 21:32:00 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 19 21:32:01 kernel: PMK: c0136261, len = 32
Dec 19 21:32:01 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 19 21:32:01 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 19 21:32:01 kernel: concatenation=: 802c1ad8, len = 76
Dec 19 21:32:01 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 43 02 86 46
Dec 19 21:32:01 kernel: 0x0010 : c2 42 43 47 7f 04 74 46 c2 b7 1a a5 e4 11 41 64
Dec 19 21:32:01 kernel: 0x0020 : 76 f5 52 b2 c2 b7 7e 47 17 09 4e bc ab 23 a6 e4
Dec 19 21:32:01 kernel: 0x0030 : 6e 4f 1b 0f 4f 08 87 be 84 1d 41 dd e2 2d ee 91
Dec 19 21:32:01 kernel: 0x0040 : e9 1d 6e 22 e2 26 11 30 13 0b 30 b9
Dec 19 21:34:59 kernel: Received RSNIE in Assoc-Req: c0151fff, len = 22
Dec 19 21:34:59 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 19 21:34:59 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 19 21:35:00 kernel: PMK: c0136261, len = 32
Dec 19 21:35:00 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 19 21:35:00 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 19 21:35:00 kernel: concatenation=: 802c1ad8, len = 76
Dec 19 21:35:00 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 8d 0e 68 73
Dec 19 21:35:00 kernel: 0x0010 : 78 c0 73 f1 9f 89 03 b0 3b 05 4f a8 7d 44 15 df
Dec 19 21:35:00 kernel: 0x0020 : 5d f8 20 71 03 8b e3 a1 3a 16 5e 94 fb 7c 1e be
Dec 19 21:35:00 kernel: 0x0030 : 1b 93 5a 17 89 00 4c 96 67 7c ef 7a c8 9b e1 60
Dec 19 21:35:00 kernel: 0x0040 : 3e 9d 06 70 d4 fa 29 33 d8 f4 62 a3
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=1!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=2!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=3!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=4!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=5!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=6!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=7!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=8!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=9!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=10!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=11!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=12!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=13!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=14!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=15!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=16!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=17!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=18!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=19!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=20!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=21!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=22!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=23!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=24!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=25!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=26!
Dec 19 21:39:45 kernel: Qidx(0), not enough space in MgmtRing, MgmtRingFullCount=27!
Dec 19 21:39:45 kernel: acm_msg> ACM_MEM_Alloc_Num = 2
Dec 19 21:39:45 kernel: acm_msg> ACM_MEM_Free_Num  = 2
Dec 19 21:39:45 kernel: acm_msg> ACM_MEM_Alloc_Num = 1
Dec 19 21:39:45 kernel: acm_msg> ACM_MEM_Free_Num  = 1
Dec 19 21:39:45 kernel: RtmpOSNetDevDetach(): RtmpOSNetDeviceDetach(), dev->name=ra0!
Dec 19 21:39:47 kernel: === pAd = c063a000, size = 815528 ===
Dec 19 21:39:47 kernel: <-- RTMPAllocAdapterBlock, Status=0
Dec 19 21:39:47 syslog: module RT3090_ap_util not found in modules.dep
Dec 19 21:39:47 syslog: module RT3090_ap_net not found in modules.dep
Dec 19 21:39:48 kernel: RX DESC a7976000  size = 2048
Dec 19 21:39:48 kernel: <-- RTMPAllocTxRxRingMemory, Status=0
Dec 19 21:39:48 kernel: RTMP_TimerListAdd: add timer obj c0180568!
Dec 19 21:39:48 kernel: RTMP_TimerListAdd: add timer obj c0139034!
Dec 19 21:39:48 kernel: RTMP_TimerListAdd: add timer obj c0138c30!
Dec 19 21:39:48 kernel: RTMP_TimerListAdd: add timer obj c0139000!
Dec 19 21:39:48 kernel: RTMP_TimerListAdd: add timer obj c013925c!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c01391a8!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c01391d4!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c0139200!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c013c134!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c013bd30!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c013c100!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c013c35c!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c013c2a8!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c013c2d4!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c013c300!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c013f234!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c013ee30!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c013f200!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c013f45c!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c013f3a8!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c013f3d4!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c013f400!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c0142334!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c0141f30!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c0142300!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c014255c!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c01424a8!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c01424d4!
Dec 19 21:39:49 kernel: RTMP_TimerListAdd: add timer obj c0142500!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c0145434!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c0145030!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c0145400!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014565c!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c01455a8!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c01455d4!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c0145600!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c0148534!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c0148130!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c0148500!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014875c!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c01486a8!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c01486d4!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c0148700!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014b634!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014b230!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014b600!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014b85c!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014b7a8!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014b7d4!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014b800!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014e734!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014e330!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014e700!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014e95c!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014e8a8!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014e8d4!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014e900!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c015731c!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c0157420!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c0157344!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014eb6c!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c01364dc!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c01395dc!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c013c6dc!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c013f7dc!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c01428dc!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c01459dc!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c0148adc!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014bbdc!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c014e998!
Dec 19 21:39:50 kernel: Key3Str is Invalid key length(0) or Type(0)
Dec 19 21:39:50 kernel: MCS Set = ff ff 00 00 00
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj 86481154!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj 86481180!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c05ebb04!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj 864811cc!
Dec 19 21:39:50 kernel: SYNC - BBP R4 to 20MHz.l
Dec 19 21:39:50 kernel: =====================================================
Dec 19 21:39:50 kernel: Channel 1 : Dirty = 0, False CCA = 3, Busy Time = 51, Skip Channel = FALSE
Dec 19 21:39:50 kernel: Channel 2 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Dec 19 21:39:50 kernel: Channel 3 : Dirty = 0, False CCA = 3, Busy Time = 115, Skip Channel = FALSE
Dec 19 21:39:50 kernel: Channel 4 : Dirty = 0, False CCA = 3, Busy Time = 105, Skip Channel = FALSE
Dec 19 21:39:50 kernel: Channel 5 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Dec 19 21:39:50 kernel: Channel 6 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Dec 19 21:39:50 kernel: Channel 7 : Dirty = 0, False CCA = 7, Busy Time = 200, Skip Channel = FALSE
Dec 19 21:39:50 kernel: Channel 8 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Dec 19 21:39:50 kernel: Channel 9 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Dec 19 21:39:50 kernel: Channel 10 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Dec 19 21:39:50 kernel: Channel 11 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Dec 19 21:39:50 kernel: Channel 12 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Dec 19 21:39:50 kernel: Channel 13 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Dec 19 21:39:50 kernel: Rule 1 CCA value : Min Dirtiness (Include extension channel) ==> Select Channel 1
Dec 19 21:39:50 kernel: Min Dirty = 4294967295
Dec 19 21:39:50 kernel: ExChannel = 0 , 0
Dec 19 21:39:50 kernel: BW        = 20
Dec 19 21:39:50 kernel: Main bssid = 10:bf:48:81:b5:68
Dec 19 21:39:50 kernel: <==== rt28xx_init, Status=0
Dec 19 21:39:50 kernel: 0x1300 = 00064380
Dec 19 21:39:50 kernel: RX DESC a666c000  size = 2048
Dec 19 21:39:50 kernel: <-- RTMPAllocTxRxRingMemory, Status=0
Dec 19 21:39:50 kernel: Key1Str is Invalid key length(0) or Type(0)
Dec 19 21:39:50 kernel: Key2Str is Invalid key length(0) or Type(0)
Dec 19 21:39:50 kernel: Key4Str is Invalid key length(0) or Type(0)
Dec 19 21:39:50 kernel: 1. Phy Mode = 8
Dec 19 21:39:50 kernel: 2. Phy Mode = 8
Dec 19 21:39:50 kernel: 3. Phy Mode = 8
Dec 19 21:39:50 kernel: RTMPSetPhyMode: channel is out of range, use first channel=0
Dec 19 21:39:50 kernel: MCS Set = ff ff ff 00 01
Dec 19 21:39:50 kernel: Rule 1 CCA value : Min Dirtiness (Include extension channel) ==> Select Channel 36
Dec 19 21:39:50 kernel: BW        = 40
Dec 19 21:39:50 kernel: Main bssid = 10:bf:48:81:b5:6c
Dec 19 21:39:50 kernel: ERROR!!! RTMPCancelTimer failed, Timer hasn't been initialize!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c0195ca8!
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c0195e5c!
Dec 19 21:39:50 kernel: Received RSNIE in Assoc-Req: c01559a7, len = 22
Dec 19 21:39:50 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 19 21:39:50 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 19 21:39:50 kernel: RTMP_TimerListAdd: add timer obj c01beab0!
Dec 19 21:39:51 kernel: RTMP_TimerListAdd: add timer obj c01c22c0!
Dec 19 21:39:51 kernel: PMK: c0136261, len = 32
Dec 19 21:39:51 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 19 21:39:51 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 19 21:39:51 kernel: concatenation=: 802c1b08, len = 76
Dec 19 21:39:51 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 1f 89 07 6e
Dec 19 21:39:51 kernel: 0x0010 : 76 ea 91 59 8a ce ac ed ce d9 ed 9d 93 12 31 26
Dec 19 21:39:51 kernel: 0x0020 : ed 9c d9 cd 31 91 e6 ec 6e cc 76 67 d1 76 c8 4d
Dec 19 21:39:51 kernel: 0x0030 : d5 1f 15 96 e8 a3 4a 59 12 53 dd 9b c8 55 d1 59
Dec 19 21:39:51 kernel: 0x0040 : 8a c4 e4 fe b9 17 11 9c 08 29 07 76
Dec 19 21:39:53 kernel: RTMP_TimerListAdd: add timer obj c01beae8!
Dec 19 21:39:54 kernel: ERROR!!! RTMPCancelTimer failed, Timer hasn't been initialize!
Dec 19 21:39:54 kernel: RTMP_TimerListAdd: add timer obj c0196708!
Dec 19 21:39:54 kernel: RTMP_TimerListAdd: add timer obj c01968bc!
Dec 19 21:39:54 kernel: Received RSNIE in Assoc-Req: c0154ce3, len = 22
Dec 19 21:39:54 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 19 21:39:54 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 19 21:39:54 kernel: RTMP_TimerListAdd: add timer obj c01beb20!
Dec 19 21:39:54 kernel: PMK: c0136261, len = 32
Dec 19 21:39:54 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 19 21:39:54 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 19 21:39:54 kernel: concatenation=: 802c1b08, len = 76
Dec 19 21:39:54 kernel: 0x0000 : 10 bf 48 81 b5 68 18 87 96 8f a1 f1 4e a3 16 39
Dec 19 21:39:54 kernel: 0x0010 : 86 d1 ea 33 f9 fd d8 c2 7e b6 16 3f 71 65 fb 1e
Dec 19 21:39:54 kernel: 0x0020 : 43 30 95 aa 4d 79 10 2a 2f 58 9a f6 fa a1 3c 34
Dec 19 21:39:54 kernel: 0x0030 : cf 14 30 74 87 78 e9 df db 48 6b 6a ff 20 b1 f0
Dec 19 21:39:54 kernel: 0x0040 : c5 c3 61 30 a0 74 99 6c 5e b9 9d 70
Dec 19 21:39:54 kernel: RTMP_TimerListAdd: add timer obj c01c230c!
Mention it on the Asus support forums, they'll look into it.
Did you do a full reset using the button on the back after flashing the upgrade? Quite a few people have said you should do that, I'm not completely sure why perhaps it's just to clear away any old settings.
Gah! I'll give it a go (full reset) tomorrow night maybe if I have time, I have my work's Christmas do so won't get back in until late. ;)
So I've done a full factory reset on the beta 317 firmware - after 10 minutes I already have an error:
Code:
Dec 22 20:13:05 kernel: RTMP_TimerListAdd: add timer obj c01beb58!
Anyone know what this actually means? :/ :(
EDIT: More already!
Code:
Dec 22 20:32:04 kernel: Received RSNIE in Assoc-Req: c0154cd7, len = 22
Dec 22 20:32:04 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 22 20:32:04 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 22 20:32:05 kernel: PMK: c0136261, len = 32
Dec 22 20:32:05 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 22 20:32:05 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 22 20:32:05 kernel: concatenation=: 802c1b08, len = 76
Dec 22 20:32:05 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 2d 43 95 e0
Dec 22 20:32:05 kernel: 0x0010 : 5e 0f 0f 81 07 ee 3f 73 fb 9a 46 5f 32 fb 2f bf
Dec 22 20:32:05 kernel: 0x0020 : 82 01 10 0b ff 4f 05 84 a7 ba c2 2f 97 f9 21 90
Dec 22 20:32:05 kernel: 0x0030 : 8a 89 96 c1 a1 34 5b 31 a0 9d 87 09 0a 6e 67 7d
Dec 22 20:32:05 kernel: 0x0040 : e2 af 0e 90 b1 e8 c0 38 ed 36 38 69
That doesn't actually say there's an error, does it work?
The fact I never had any of these 'messages' before but now it is filling my System Log worries me. Regardless I don't appear to actually be having any network/performance issues. It is kind of like a placebo effect, it is making me worry yet there is nothing not working..
Couple of actual ERRORS in this.. I think I might rollback to the official 314 firmware. Just makes it rather nerving.
Code:
Dec 23 09:43:15 kernel: Replay Counter Different in pairwise msg 2 of 4-way handshake!
Dec 23 09:43:15 kernel: Receive replay counter : c0154669, len = 8
Dec 23 09:43:15 kernel: 0x0000 : 00 00 00 00 00 00 00 03
Dec 23 09:43:15 kernel: Current replay counter : c0197d32, len = 8
Dec 23 09:43:15 kernel: 0x0000 : 00 00 00 00 00 00 00 04
Dec 23 09:43:15 kernel: PMK: c0136261, len = 32
Dec 23 09:43:15 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 09:43:15 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 09:43:15 kernel: concatenation=: 802c1b08, len = 76
Dec 23 09:43:15 kernel: 0x0000 : 10 bf 48 81 b5 68 18 87 96 8f a1 f1 22 08 7e 77
Dec 23 09:43:15 kernel: 0x0010 : 76 63 ea f6 32 bb c4 cf 97 1b 32 00 f3 e6 39 58
Dec 23 09:43:15 kernel: 0x0020 : cd f4 5a 02 24 7e 98 98 4d 01 94 8c dc 6a 8a 07
Dec 23 09:43:15 kernel: 0x0030 : 37 23 9d 6a e2 6e b6 06 11 af 2e cf 67 e7 00 be
Dec 23 09:43:15 kernel: 0x0040 : 0b fc b7 9f 22 26 04 ed f7 87 3f 07
Dec 23 09:43:15 kernel: RTMP_TimerListAdd: add timer obj c01c23a4!
Dec 23 09:43:22 kernel: RTMP_TimerListAdd: add timer obj c01beb90!
Dec 23 09:45:17 kernel: RTMP_TimerListAdd: add timer obj c01bebc8!
Dec 23 09:46:53 kernel: RTMP_TimerListAdd: add timer obj c01bec00!
Dec 23 09:52:06 kernel: RTMP_TimerListAdd: add timer obj c01c23f0!
Dec 23 09:59:37 kernel: ERROR!!! RTMPCancelTimer failed, Timer hasn't been initialize!
Dec 23 09:59:37 kernel: RTMP_TimerListAdd: add timer obj c0198628!
Dec 23 09:59:37 kernel: RTMP_TimerListAdd: add timer obj c01987dc!
Dec 23 09:59:37 kernel: Received RSNIE in Assoc-Req: c0151fff, len = 22
Dec 23 09:59:37 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 09:59:37 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 23 09:59:37 kernel: RTMP_TimerListAdd: add timer obj c01bec38!
Dec 23 09:59:37 kernel: RTMP_TimerListAdd: add timer obj c01c243c!
Dec 23 09:59:37 kernel: PMK: c0136261, len = 32
Dec 23 09:59:37 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 09:59:37 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 09:59:37 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 09:59:37 kernel: 0x0000 : 00 17 c4 b5 c8 99 10 bf 48 81 b5 68 9d 9c 38 02
Dec 23 09:59:37 kernel: 0x0010 : 92 67 f9 7f 0e a0 c0 c4 94 03 16 39 2f 8d 7a a9
Dec 23 09:59:37 kernel: 0x0020 : 96 a8 5a 83 30 b7 e4 5d 97 bb a8 19 d3 9b bc 90
Dec 23 09:59:37 kernel: 0x0030 : db 5d 12 59 5f 35 b0 45 06 0b 80 66 f7 bb 8a be
Dec 23 09:59:37 kernel: 0x0040 : 83 7a 36 10 c0 f8 88 4a 88 ca e0 5d
Dec 23 10:01:46 kernel: RTMP_TimerListAdd: add timer obj c01bec70!
Dec 23 10:22:15 kernel: Received RSNIE in Assoc-Req: c0156cdf, len = 22
Dec 23 10:22:15 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 10:22:15 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 10:22:15 kernel: PMK: c0136261, len = 32
Dec 23 10:22:15 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 10:22:15 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 10:22:15 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 10:22:15 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 c7 84 e5 f8
Dec 23 10:22:15 kernel: 0x0010 : 8e 8a 62 c1 8f fc 0b c1 8c ba 84 90 74 e1 3c a2
Dec 23 10:22:15 kernel: 0x0020 : c9 f2 3c 6c a2 2f 9d 51 77 59 b7 f9 e2 4b ed a3
Dec 23 10:22:15 kernel: 0x0030 : 25 ce 5c ea e7 57 75 77 a8 83 77 c1 be 09 e0 98
Dec 23 10:22:15 kernel: 0x0040 : f6 74 67 4c c5 9a 59 a5 9a 5e 5a 15
I was getting loads of errors on 314, the WiFi also seemed to be very sluggish and unstable with a lot of DNS issues. Since upgrading to 317 I have to admit that I am now very pleased with the router having been on the verge of sending the unit back, the WiFi is spot on and for the first time I'm able to stream HD videos over it, I longer get the DNS issues now and everything appears nice and stable/quick.
My current logs look remarkably similar to the logs that you have posted but I'm not concerned by what I see (probably because I don't know what they mean). As far as I'm aware 317 is still in beta so maybe these errors will get ironed out (I've also read of the presence of version 318).
It's comforting to know that Asus are actively working on the firmware and listen to feedback on their forum although you could argue they shouldn't have released it in the poor state that they did.
That's basically my opinion some in my house are moaning about the internet but I don't want to put BETA firmware on it. It works fine for me though.
Yeah it is comforting to know ASUS are working on the firmware. Still not actually had any wireless issues or performance drops. It just erks me all these logs.. I mean look at it throughout the whole of today[?!]..
I was on the verge of sending it back. But considering with different firmware versions the errors/logs vary and can be minimised, I don't think the kit is faulty. Just the firmware needs ironing out.
Code:
Dec 23 10:35:07 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 10:35:07 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 10:35:07 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 10:35:07 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 ae 77 e9 05
Dec 23 10:35:07 kernel: 0x0010 : 85 b7 38 62 4b 40 e6 f3 a8 c0 34 d5 8d 6f 85 78
Dec 23 10:35:07 kernel: 0x0020 : 58 10 6d f6 2a 64 29 41 a4 6c f9 55 cc 6a 39 56
Dec 23 10:35:07 kernel: 0x0030 : ca b5 54 ae b5 19 51 90 8c 81 c8 1e 81 eb 1e bb
Dec 23 10:35:07 kernel: 0x0040 : f5 dd a2 20 22 0a 10 57 7d 43 2b cb
Dec 23 10:35:24 kernel: Received RSNIE in Assoc-Req: c015399f, len = 22
Dec 23 10:35:24 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 10:35:24 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 10:35:24 kernel: PMK: c0136261, len = 32
Dec 23 10:35:24 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 10:35:24 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 10:35:24 kernel: concatenation=: 802c1b08, len = 76
Dec 23 10:35:24 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 49 5b b5 23
Dec 23 10:35:24 kernel: 0x0010 : 52 37 91 bc 72 1e 90 f4 78 5f 7a 0d 2f 92 7c 90
Dec 23 10:35:24 kernel: 0x0020 : 1b 7b db da bd a4 12 dc 96 e1 48 f0 4e 7b e8 b7
Dec 23 10:35:24 kernel: 0x0030 : 1b 8a ad a0 32 16 26 1e c4 52 ed 64 41 a3 93 02
Dec 23 10:35:24 kernel: 0x0040 : 2e f6 3e 8f 49 47 3b a7 65 1f e9 d9
Dec 23 10:38:38 kernel: Received RSNIE in Assoc-Req: c01559a7, len = 22
Dec 23 10:38:38 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 10:38:38 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 10:38:38 kernel: PMK: c0136261, len = 32
Dec 23 10:38:38 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 10:38:38 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 10:38:38 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 10:38:38 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 63 f1 e0 77
Dec 23 10:38:38 kernel: 0x0010 : f8 81 88 18 40 c6 f9 c9 63 6e 36 e5 b7 2b 8d 47
Dec 23 10:38:38 kernel: 0x0020 : 2b 8f 47 00 38 00 80 0e 00 e8 f1 77 70 67 23 6e
Dec 23 10:38:38 kernel: 0x0030 : b6 f1 03 ee 37 cd 2c cb e6 d3 12 ce 20 54 d3 bb
Dec 23 10:38:38 kernel: 0x0040 : f2 6b 3d 3f 93 9b 55 f2 b5 87 7f e6
Dec 23 10:43:07 kernel: !!! (0) Can't allocate reordering mpdu blk
Dec 23 10:46:10 kernel: Received RSNIE in Assoc-Req: c015132f, len = 22
Dec 23 10:46:10 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 10:46:10 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 10:46:10 kernel: PMK: c0136261, len = 32
Dec 23 10:46:10 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 10:46:10 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 10:46:10 kernel: concatenation=: 802c1b08, len = 76
Dec 23 10:46:10 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 86 ea ed b2
Dec 23 10:46:11 kernel: 0x0010 : a8 56 9d 87 05 99 dd e3 e3 94 26 17 c1 c5 96 75
Dec 23 10:46:11 kernel: 0x0020 : 6a b9 62 de cf b4 4b 9c a7 62 46 5d d8 dc 39 1c
Dec 23 10:46:11 kernel: 0x0030 : 6e 3e 71 f5 8f ac 05 38 d6 3a 63 a1 1d 0b 17 a5
Dec 23 10:46:11 kernel: 0x0040 : 85 a4 2d 20 2d f3 90 67 7c c5 cc 5a
Dec 23 10:47:09 kernel: Received RSNIE in Assoc-Req: c0151997, len = 22
Dec 23 10:47:09 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 10:47:09 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 23 10:47:09 kernel: PMK: c0136261, len = 32
Dec 23 10:47:10 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 10:47:10 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 10:47:10 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 10:47:10 kernel: 0x0000 : 00 17 c4 b5 c8 99 10 bf 48 81 b5 68 45 c6 64 34
Dec 23 10:47:10 kernel: 0x0010 : 3a 35 59 a2 68 cd 85 7c 52 55 a6 1a 80 92 b0 7b
Dec 23 10:47:10 kernel: 0x0020 : 2e 40 56 43 5a 7e 95 f6 b6 5c 78 82 46 bb 32 48
Dec 23 10:47:10 kernel: 0x0030 : 09 15 79 db 75 58 b1 5c 8f da 65 e3 85 1c 39 de
Dec 23 10:47:10 kernel: 0x0040 : 78 48 05 a6 5d 44 33 40 80 af 28 72
Dec 23 10:52:05 kernel: Received RSNIE in Assoc-Req: c014fff7, len = 22
Dec 23 10:52:05 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 10:52:05 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 10:52:05 kernel: PMK: c0136261, len = 32
Dec 23 10:52:05 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 10:52:05 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 10:52:05 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 10:52:05 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 4b bc 44 38
Dec 23 10:52:05 kernel: 0x0010 : bc 7d c7 d2 c1 6f 16 fb 6f b0 7d 81 ec 08 3f 72
Dec 23 10:52:05 kernel: 0x0020 : f7 2b 46 a2 ca ec ae ca ec a2 9a e9 52 36 0d 7b
Dec 23 10:52:05 kernel: 0x0030 : dd ae 6b 87 6b 47 6b b6 0f ce 49 f9 51 2d 28 86
Dec 23 10:52:05 kernel: 0x0040 : 50 8c fc f6 15 c4 5c 7d 15 f3 bc 09
Dec 23 10:52:37 kernel: Received RSNIE in Assoc-Req: c01559a7, len = 22
Dec 23 10:52:37 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 10:52:37 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 10:52:37 kernel: PMK: c0136261, len = 32
Dec 23 10:52:38 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 10:52:38 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 10:52:38 kernel: concatenation=: 802c1b08, len = 76
Dec 23 10:52:38 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 39 ed 59 dc
Dec 23 10:52:38 kernel: 0x0010 : 86 cf f2 86 59 67 92 e7 f3 4e f6 fe db e1 f0 69
Dec 23 10:52:38 kernel: 0x0020 : c8 ed f3 91 a9 8b e2 59 f1 e8 5e a0 43 8e e3 8f
Dec 23 10:52:38 kernel: 0x0030 : 38 f7 38 43 c2 19 10 c9 86 48 9b 7c db e6 df 33
Dec 23 10:52:38 kernel: 0x0040 : 06 62 cc ec ce ca 76 51 4d 77 6b be
Dec 23 10:52:38 kernel: Received RSNIE in Assoc-Req: c0153337, len = 22
Dec 23 10:52:38 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 10:52:38 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 10:52:39 kernel: PMK: c0136261, len = 32
Dec 23 10:52:39 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 10:52:39 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 10:52:39 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 10:52:39 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 04 12 df 6e
Dec 23 10:52:39 kernel: 0x0010 : 04 8b 48 b5 74 a8 5a ba d5 d3 a2 cd 2c d1 66 8d
Dec 23 10:52:39 kernel: 0x0020 : 68 d6 8d 6f 29 09 48 4b 7b 4b 4b 4c 90 e3 77 75
Dec 23 10:52:39 kernel: 0x0030 : 0c b8 d5 2c aa ef f6 25 e3 d9 db 47 71 5e fa e7
Dec 23 10:52:39 kernel: 0x0040 : db ed 08 db 0d a2 3f e0 43 e7 90 04
Dec 23 10:53:29 kernel: Received RSNIE in Assoc-Req: c014f327, len = 22
Dec 23 10:53:29 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 10:53:29 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 10:53:29 kernel: PMK: c0136261, len = 32
Dec 23 10:53:29 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 10:53:29 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 10:53:29 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 10:53:29 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 cf 25 86 d6
Dec 23 10:53:29 kernel: 0x0010 : 6d 6a 29 5b b5 24 a9 26 6d 9b d9 bf 32 01 90 0d
Dec 23 10:53:29 kernel: 0x0020 : ff 25 0d a2 92 ee 97 72 88 d2 8d 23 e5 d9 bd 8b
Dec 23 10:53:29 kernel: 0x0030 : 01 9f 2e 6d 19 a9 19 6c bc 63 a5 ca 99 b7 87 23
Dec 23 10:53:29 kernel: 0x0040 : 2d 6c 7c 32 9d c2 18 60 48 eb 0a f6
Dec 23 10:53:33 kernel: Received RSNIE in Assoc-Req: c014f327, len = 22
Dec 23 10:53:33 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 10:53:33 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 10:53:34 kernel: PMK: c0136261, len = 32
Dec 23 10:53:34 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 10:53:34 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 10:53:34 kernel: concatenation=: 802c1b08, len = 76
Dec 23 10:53:34 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 68 f7 8f 78
Dec 23 10:53:34 kernel: 0x0010 : 84 38 bc 77 e3 be e2 0b df 40 05 fa 5f a9 02 b1
Dec 23 10:53:34 kernel: 0x0020 : ea 77 a7 70 3b 80 47 fd c0 10 ff 7c cc e8 42 6b
Dec 23 10:53:34 kernel: 0x0030 : f2 57 ef 22 d0 17 56 b4 1a 85 34 16 3d 14 35 43
Dec 23 10:53:34 kernel: 0x0040 : 07 44 cf 3f a9 f4 7a 2d ba 45 86 d3
Dec 23 11:01:43 kernel: Received RSNIE in Assoc-Req: c015533f, len = 22
Dec 23 11:01:43 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 11:01:43 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 11:01:43 kernel: PMK: c0136261, len = 32
Dec 23 11:01:43 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 11:01:43 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 11:01:43 kernel: concatenation=: 802c1b08, len = 76
Dec 23 11:01:43 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 13 f5 4a 5d
Dec 23 11:01:43 kernel: 0x0010 : 6b b3 ce 23 43 16 6e f8 d6 99 c9 8a 8c f3 32 21
Dec 23 11:01:43 kernel: 0x0020 : 95 5f 43 d5 d8 ab 82 89 e7 a1 f3 56 9e c8 ec 87
Dec 23 11:01:43 kernel: 0x0030 : 9b c3 43 c0 1e 01 f0 0a 00 a5 05 2d ad 2e 69 77
Dec 23 11:01:43 kernel: 0x0040 : 4b be bb ef 20 80 08 0d bf 93 03 63
Dec 23 11:02:29 kernel: Received RSNIE in Assoc-Req: c0154cd7, len = 22
Dec 23 11:02:29 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 11:02:29 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 11:02:29 kernel: PMK: c0136261, len = 32
Dec 23 11:02:29 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 11:02:29 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 11:02:29 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 11:02:29 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 8c d6 11 6b
Dec 23 11:02:29 kernel: 0x0010 : b3 96 57 a8 6f 38 13 cc 9d 86 c4 39 65 d6 57 a3
Dec 23 11:02:29 kernel: 0x0020 : 33 69 bf d3 af ef 2b 23 8d 61 91 7c c2 c2 2c 26
Dec 23 11:02:29 kernel: 0x0030 : 3d 9a ec d0 66 83 97 ca 7c ae 1a 8f 2b 83 b8 3b
Dec 23 11:02:29 kernel: 0x0040 : 83 ba e2 2c 22 c5 2c 5f c5 f6 d0 4f
Dec 23 11:05:08 kernel: Received RSNIE in Assoc-Req: c0152ccf, len = 22
Dec 23 11:05:08 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 11:05:08 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 11:05:08 kernel: PMK: c0136261, len = 32
Dec 23 11:05:09 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 11:05:09 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 11:05:09 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 11:05:09 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 40 e1 0e 16
Dec 23 11:05:09 kernel: 0x0010 : e1 61 0b 08 4f 71 08 e6 71 96 8c b2 34 d7 b2 86
Dec 23 11:05:09 kernel: 0x0020 : d7 9c bc e4 ce 4a 1b 5f 4a 08 50 40 45 e5 44 94
Dec 23 11:05:09 kernel: 0x0030 : 5c 22 8e a6 91 67 cd 20 2c 97 a8 34 98 3b a5 f4
Dec 23 11:05:09 kernel: 0x0040 : 0e 1b 47 69 78 e4 7e d5 1a 99 c7 8f
Dec 23 11:07:55 kernel: Received RSNIE in Assoc-Req: c0153337, len = 22
Dec 23 11:07:55 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 11:07:55 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 11:07:56 kernel: PMK: c0136261, len = 32
Dec 23 11:07:56 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 11:07:56 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 11:07:56 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 11:07:56 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 4c 0e c0 e6
Dec 23 11:07:56 kernel: 0x0010 : 0e 6a 19 5c 35 1b 51 ba 1b a5 ba 55 d2 ad 2a d4
Dec 23 11:07:56 kernel: 0x0020 : 52 b3 d4 c6 59 cd 63 20 32 0a df 52 5e 5f c1 80
Dec 23 11:07:56 kernel: 0x0030 : ad db 17 5d 48 30 7c 1c ad dd d2 9c 3d 77 fc fa
Dec 23 11:07:56 kernel: 0x0040 : 6d 5a f4 61 7a 24 bb 33 bf 18 e6 09
Dec 23 11:14:14 kernel: Received RSNIE in Assoc-Req: c015600f, len = 22
Dec 23 11:14:14 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 11:14:14 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 23 11:14:14 kernel: PMK: c0136261, len = 32
Dec 23 11:14:14 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 11:14:14 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 11:14:14 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 11:14:14 kernel: 0x0000 : 00 17 c4 b5 c8 99 10 bf 48 81 b5 68 38 2d 40 1a
Dec 23 11:14:14 kernel: 0x0010 : 00 01 20 04 08 3d 94 a3 8d 59 34 6b ea 3d d3 8e
Dec 23 11:14:14 kernel: 0x0020 : 22 e4 bf b0 9a 1e 66 e6 88 c7 4a ba bc a2 4a c8
Dec 23 11:14:14 kernel: 0x0030 : c1 64 9e 8d 5f 12 d5 c1 6f f6 9d e6 af ed 33 90
Dec 23 11:14:14 kernel: 0x0040 : 6a 01 f5 ea a9 17 e7 c1 2e 28 bd d0
Dec 23 11:14:55 kernel: Received RSNIE in Assoc-Req: c015065f, len = 22
Dec 23 11:14:55 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 11:14:55 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 11:14:56 kernel: PMK: c0136261, len = 32
Dec 23 11:14:56 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 11:14:56 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 11:14:56 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 11:14:56 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 24 f6 4f 6b
Dec 23 11:14:56 kernel: 0x0010 : f6 b6 6b 6f a4 80 b7 fc 7f c1 fc 18 e0 c4 0c 4b
Dec 23 11:14:56 kernel: 0x0020 : c4 b7 25 be d2 0e 20 ea 0e a3 8a e1 3e 72 e0 96
Dec 23 11:14:56 kernel: 0x0030 : 15 7a b7 d4 33 b6 b2 e1 3e a9 f0 e4 0e 32 61 4c
Dec 23 11:14:56 kernel: 0x0040 : 2c 0e 19 e0 24 6e 95 25 29 9f f1 59
Dec 23 11:19:05 kernel: Received RSNIE in Assoc-Req: c015600f, len = 22
Dec 23 11:19:05 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 11:19:05 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 11:19:06 kernel: PMK: c0136261, len = 32
Dec 23 11:19:06 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 11:19:06 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 11:19:06 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 11:19:06 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 4d cf 7f aa
Dec 23 11:19:06 kernel: 0x0010 : 32 82 a8 8b fc 44 e8 f7 70 45 1f 22 ee 06 3c 41
Dec 23 11:19:06 kernel: 0x0020 : d5 73 7f 6f ad df 5d b7 7e b5 61 76 55 ff 5f f0
Dec 23 11:19:06 kernel: 0x0030 : ff 03 07 e2 c0 ef 0e fd 10 29 7e b6 f5 b5 5b 5f
Dec 23 11:19:06 kernel: 0x0040 : b5 fa 50 2b 02 b5 2b 5a b5 a2 52 e9
Dec 23 11:29:14 kernel: Received RSNIE in Assoc-Req: c015065f, len = 22
Dec 23 11:29:14 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 11:29:14 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 11:29:15 kernel: PMK: c0136261, len = 32
Dec 23 11:29:15 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 11:29:15 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 11:29:15 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 11:29:15 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 62 2c 8b 6b
Dec 23 11:29:15 kernel: 0x0010 : a1 16 0c 4e 40 63 a4 b1 bc 53 5b b8 8e 5f c7 a2
Dec 23 11:29:15 kernel: 0x0020 : e0 d4 3e 4a b1 75 95 60 c1 96 8a 0a bf 9c 06 3b
Dec 23 11:29:15 kernel: 0x0030 : 9c 45 1d d3 ee 9d e9 dd 62 23 ee e4 88 da 72 5f
Dec 23 11:29:15 kernel: 0x0040 : da 07 2f c1 fc 19 3e 6f 19 0c 37 9e
Dec 23 11:35:33 kernel: Received RSNIE in Assoc-Req: c014fff7, len = 22
Dec 23 11:35:33 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 11:35:33 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 11:35:33 kernel: PMK: c0136261, len = 32
Dec 23 11:35:33 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 11:35:33 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 11:35:33 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 11:35:33 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 53 ec c1 38
Dec 23 11:35:33 kernel: 0x0010 : 09 c2 63 d4 3d 43 d4 33 a1 9d e6 2d 9d 26 d2 69
Dec 23 11:35:33 kernel: 0x0020 : 93 4e 34 e8 b1 70 74 7b 5c 26 c2 69 d3 9c 15 32
Dec 23 11:35:33 kernel: 0x0030 : 8b 32 0e d9 1c b6 59 31 ed ea 28 a6 44 6d 4b 76
Dec 23 11:35:33 kernel: 0x0040 : 5d 40 31 52 d8 4a 7e 33 a7 fa d7 7a
Dec 23 11:43:08 kernel: !!! (0) Can't allocate reordering mpdu blk
Dec 23 12:02:20 kernel: Received RSNIE in Assoc-Req: c015466f, len = 22
Dec 23 12:02:20 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 12:02:20 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 12:02:20 kernel: PMK: c0136261, len = 32
Dec 23 12:02:20 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 12:02:20 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 12:02:20 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 12:02:20 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 1a b0 2a 7c
Dec 23 12:02:20 kernel: 0x0010 : 58 32 7c d1 32 e6 68 c8 8c 8f 37 09 8f 64 7b 22
Dec 23 12:02:20 kernel: 0x0020 : 4d d7 22 81 d7 ec bf 64 f6 41 9b eb 49 fb 8b e7
Dec 23 12:02:20 kernel: 0x0030 : f9 ed 8f d7 ab 53 07 dd 76 71 13 97 c8 18 23 12
Dec 23 12:02:20 kernel: 0x0040 : 47 39 87 9b 57 a8 c4 a2 a1 33 f3 6c
Dec 23 12:16:00 kernel: Received RSNIE in Assoc-Req: c015466f, len = 22
Dec 23 12:16:00 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 12:16:00 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 12:16:00 kernel: PMK: c0136261, len = 32
Dec 23 12:16:00 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 12:16:00 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 12:16:00 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 12:16:00 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 2b 42 a5 57
Dec 23 12:16:00 kernel: 0x0010 : 4e 03 a4 8c 37 5f 28 35 24 e0 2a ec 1a e5 17 65
Dec 23 12:16:00 kernel: 0x0020 : 6d d1 19 4d 7e b7 c8 df f1 06 8b 7b 45 99 2c cc
Dec 23 12:16:00 kernel: 0x0030 : cc c2 33 d1 61 74 0b a3 45 cf a3 01 18 0f c0 7d
Dec 23 12:16:00 kernel: 0x0040 : f8 2a 7d 50 15 78 ab c7 43 85 38 5c
Dec 23 12:32:30 kernel: Received RSNIE in Assoc-Req: c015399f, len = 22
Dec 23 12:32:30 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 12:32:30 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 12:32:30 kernel: PMK: c0136261, len = 32
Dec 23 12:32:30 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 12:32:30 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 12:32:30 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 12:32:30 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 af d4 7e a0
Dec 23 12:32:30 kernel: 0x0010 : ea 07 5f 86 07 9f 3c f9 30 66 06 67 99 86 33 cc
Dec 23 12:32:30 kernel: 0x0020 : c3 32 33 26 32 66 6c ce 33 19 31 92 f8 31 73 bb
Dec 23 12:32:30 kernel: 0x0030 : 00 c7 f3 f0 0c 07 55 24 a3 bb 4c d7 96 33 ce 9c
Dec 23 12:32:30 kernel: 0x0040 : ce 9d 13 ea 28 65 e9 8d 0a b4 84 b8
Dec 23 12:33:26 kernel: Received RSNIE in Assoc-Req: c014fff7, len = 22
Dec 23 12:33:26 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 12:33:26 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 12:33:27 kernel: PMK: c0136261, len = 32
Dec 23 12:33:27 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 12:33:27 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 12:33:27 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 12:33:27 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 96 67 99 83
Dec 23 12:33:27 kernel: 0x0010 : cc 1b c1 b8 1b 82 dc 11 1f 70 08 fa 70 56 7d 4c
Dec 23 12:33:27 kernel: 0x0020 : 15 9a a6 5b 9a 4b d2 5e 92 f7 2f 76 f6 48 bc 95
Dec 23 12:33:27 kernel: 0x0030 : 81 ef 54 ba b3 20 54 b1 3f 0d 2a 21 11 80 36 1e
Dec 23 12:33:27 kernel: 0x0040 : 2d b9 4e f7 0b 02 ca 7c f3 22 b7 8c
Dec 23 12:43:09 kernel: !!! (0) Can't allocate reordering mpdu blk
Dec 23 12:43:50 kernel: Received RSNIE in Assoc-Req: c0151fff, len = 22
Dec 23 12:43:50 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 12:43:50 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 12:43:50 kernel: PMK: c0136261, len = 32
Dec 23 12:43:50 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 12:43:50 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 12:43:50 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 12:43:50 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 04 58 8a b9
Dec 23 12:43:50 kernel: 0x0010 : c9 a9 13 95 53 a8 35 f2 00 bd dc f1 09 be 14 4b
Dec 23 12:43:50 kernel: 0x0020 : fe b4 07 22 04 14 a2 29 3e df 77 fd 70 61 f9 e3
Dec 23 12:43:50 kernel: 0x0030 : cf 1c f1 c6 e3 9d 39 d3 ce 98 16 7c 67 c1 3e 0d
Dec 23 12:43:50 kernel: 0x0040 : f0 6d 06 d6 6d 67 94 c7 a6 3f 9c 03
Dec 23 12:48:33 kernel: Received RSNIE in Assoc-Req: c014f98f, len = 22
Dec 23 12:48:33 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 12:48:33 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 23 12:48:41 kernel: Received RSNIE in Assoc-Req: c01559a7, len = 22
Dec 23 12:48:41 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 12:48:41 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 23 12:48:42 kernel: Received RSNIE in Assoc-Req: c014f98f, len = 22
Dec 23 12:48:42 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 12:48:42 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 23 12:48:44 kernel: Received RSNIE in Assoc-Req: c014fff7, len = 22
Dec 23 12:48:44 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 12:48:44 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 23 12:48:44 kernel: Received RSNIE in Assoc-Req: c0152667, len = 22
Dec 23 12:48:48 kernel: PMK: c0136261, len = 32
Dec 23 12:48:48 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 12:48:48 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 12:48:48 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 12:48:48 kernel: 0x0000 : 00 17 c4 b5 c8 99 10 bf 48 81 b5 68 ce a0 5f 2a
Dec 23 12:48:48 kernel: 0x0010 : 79 0b 9e bd c4 6e d7 80 6e 88 1e 6b 97 22 c5 2d
Dec 23 12:48:48 kernel: 0x0020 : 4a 6b a6 4f e5 f0 24 65 97 1e 76 48 dc cc 00 aa
Dec 23 12:48:48 kernel: 0x0030 : 6d b4 53 43 5f 00 2c f2 02 38 07 01 60 86 d1 58
Dec 23 12:48:48 kernel: 0x0040 : 25 b5 0a 14 fd 6e 2b 2f 42 b8 82 92
Dec 23 12:48:48 kernel: Replay Counter Different in pairwise msg 2 of 4-way handshake!
Dec 23 12:48:48 kernel: Receive replay counter : c0154001, len = 8
Dec 23 12:48:48 kernel: 0x0000 : 00 00 00 00 00 00 00 01
Dec 23 12:48:48 kernel: Current replay counter : c0195e12, len = 8
Dec 23 12:48:48 kernel: 0x0000 : 00 17 c4 b5 c8 99 10 bf 48 81 b5 68 9e 54 e7 fc
Dec 23 12:48:48 kernel: 0x0010 : 97 d0 a9 5d 69 7a 23 62 1e 9f f9 ff 3c 75 61 33
Dec 23 12:48:48 kernel: 0x0020 : e3 b6 66 17 ff 76 a0 20 b1 cf b1 d2 dc cc 00 aa
Dec 23 12:48:48 kernel: Receive replay counter : c014f989, len = 8
Dec 23 12:48:48 kernel: 0x0000 : 00 00 00 00 00 00 00 02
Dec 23 12:48:48 kernel: 0x0000 : 00 00 00 00 00 00 00 04
Dec 23 12:48:49 kernel: PMK: c0136261, len = 32
Dec 23 12:48:49 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 12:48:49 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 12:48:49 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 12:48:49 kernel: 0x0000 : 00 17 c4 b5 c8 99 10 bf 48 81 b5 68 79 9b aa d7
Dec 23 12:48:49 kernel: 0x0010 : 36 45 ba 75 9b 30 f6 36 76 27 3d 54 07 c9 58 24
Dec 23 12:48:49 kernel: 0x0020 : 37 33 ec 46 38 16 80 30 95 26 b9 2b dc cc 00 aa
Dec 23 12:48:49 kernel: 0x0030 : 6d b4 53 43 5f 00 2c f2 02 38 07 01 60 86 d1 58
Dec 23 12:48:49 kernel: 0x0040 : 25 b5 0a 14 fd 6e 2b 2f 42 b8 82 92
Dec 23 12:48:49 kernel: Replay Counter Different in pairwise msg 2 of 4-way handshake!
Dec 23 12:48:49 kernel: Receive replay counter : c0151329, len = 8
Dec 23 12:48:49 kernel: 0x0000 : 00 00 00 00 00 00 00 03
Dec 23 12:48:49 kernel: Current replay counter : c0195e12, len = 8
Dec 23 12:48:49 kernel: 0x0000 : 00 00 00 00 00 00 00 04
Dec 23 12:48:49 kernel: 0x0000 : 00 17 c4 b5 c8 99 10 bf 48 81 b5 68 b5 f1 45 71
Dec 23 12:48:49 kernel: 0x0010 : f8 5c 3f 75 11 40 b6 fb b1 24 6e ed 8c 6b b8 2c
Dec 23 12:48:49 kernel: 0x0020 : 55 7e 6d 1f ba a1 d1 63 67 c2 cd 37 dc cc 00 aa
Dec 23 12:54:10 kernel: Received RSNIE in Assoc-Req: c0154cd7, len = 22
Dec 23 12:54:10 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 12:54:10 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 12:54:10 kernel: PMK: c0136261, len = 32
Dec 23 12:54:10 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 12:54:10 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 12:54:10 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 12:54:10 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 c9 92 54 87
Dec 23 12:54:10 kernel: 0x0010 : 75 3d f3 f6 74 b4 0f d9 54 d2 6e 77 d1 da 06 23
Dec 23 12:54:10 kernel: 0x0020 : d1 73 b9 9e b8 cc 03 b9 4f 35 d3 14 fd d6 22 9b
Dec 23 12:54:10 kernel: 0x0030 : eb 25 59 2a 6d 57 2a 84 54 22 5e ef ee f2 ef 20
Dec 23 12:54:10 kernel: 0x0040 : 79 07 c8 3f 7c 0e c0 ec 07 62 3b 11
Dec 23 12:57:41 kernel: Received RSNIE in Assoc-Req: c0154cd7, len = 22
Dec 23 12:57:41 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 12:57:41 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 12:57:41 kernel: PMK: c0136261, len = 32
Dec 23 12:57:41 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 12:57:41 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 12:57:41 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 12:57:41 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 07 ca c1 aa
Dec 23 12:57:41 kernel: 0x0010 : e5 57 55 74 ab a7 a2 c2 d3 d6 c2 9d eb 16 58 b5
Dec 23 12:57:41 kernel: 0x0020 : 8b 5a 4a 55 52 ab 95 58 55 86 58 68 50 d0 dd 60
Dec 23 12:57:41 kernel: 0x0030 : 85 35 f7 61 84 df 63 3c 2a c0 a3 61 b3 e4 7f c8
Dec 23 12:57:41 kernel: 0x0040 : a9 bd a8 74 5b 8c b6 18 86 97 85 d1
Dec 23 13:05:45 kernel: Received RSNIE in Assoc-Req: c01559a7, len = 22
Dec 23 13:05:45 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 13:05:45 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 13:05:45 kernel: PMK: c0136261, len = 32
Dec 23 13:05:45 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 13:05:45 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 13:05:45 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 13:05:45 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 77 4d b9 cf
Dec 23 13:05:45 kernel: 0x0010 : a1 5b e5 9f 37 32 f7 b7 2e 8d 25 2f 9e de bd 22
Dec 23 13:05:45 kernel: 0x0020 : e4 1f cd a7 50 c4 f2 45 33 11 01 ec c0 fb f0 45
Dec 23 13:05:45 kernel: 0x0030 : fb ae 45 1a 28 d6 8d 68 29 7a 97 af bd 79 d7 9d
Dec 23 13:05:45 kernel: 0x0040 : 86 2e ce 88 8b bd 44 29 bd 61 14 f6
Dec 23 13:14:05 kernel: Received RSNIE in Assoc-Req: c0152ccf, len = 22
Dec 23 13:14:05 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 13:14:05 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 13:14:05 kernel: PMK: c0136261, len = 32
Dec 23 13:14:05 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 13:14:05 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 13:14:05 kernel: concatenation=: 802c1b08, len = 76
Dec 23 13:14:05 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 92 68 63 3b
Dec 23 13:14:05 kernel: 0x0010 : 3d ec d8 93 4d 6b 82 50 c7 0c 54 44 f2 b5 85 6c
Dec 23 13:14:05 kernel: 0x0020 : 16 46 57 83 44 4b de 11 73 20 5f 49 b7 e7 7e 7a
Dec 23 13:14:05 kernel: 0x0030 : 0c 2c c2 c1 d3 e8 c1 7f f4 07 bf 86 07 9c 86 34
Dec 23 13:14:05 kernel: 0x0040 : 31 a0 1a 0f 5f 01 f0 1e 80 f3 f0 c9
Dec 23 13:24:25 kernel: Received RSNIE in Assoc-Req: c0154cd7, len = 22
Dec 23 13:24:25 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 13:24:25 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 13:24:25 kernel: PMK: c0136261, len = 32
Dec 23 13:24:25 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 13:24:25 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 13:24:25 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 13:24:25 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 26 ce c9 89
Dec 23 13:24:25 kernel: 0x0010 : 67 60 76 0c b0 67 7c c5 33 a2 3a 21 2e f5 77 aa
Dec 23 13:24:25 kernel: 0x0020 : 7a a8 55 72 54 6a 5c a9 35 6f 56 f8 95 71 4c 5f
Dec 23 13:24:25 kernel: 0x0030 : db 38 b5 e7 8c 88 b5 e8 cf dd d3 9c b8 80 dc 55
Dec 23 13:24:25 kernel: 0x0040 : ab 8e 3c 31 83 ce d9 11 f4 88 4b be
Dec 23 13:26:10 kernel: Received RSNIE in Assoc-Req: c0151997, len = 22
Dec 23 13:26:10 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 13:26:10 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 13:26:10 kernel: PMK: c0136261, len = 32
Dec 23 13:26:10 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 13:26:10 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 13:26:10 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 13:26:10 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 79 38 93 8e
Dec 23 13:26:10 kernel: 0x0010 : 9c 72 1c 6c c6 c9 93 63 9b 1c b1 c6 e3 9e c6 19
Dec 23 13:26:10 kernel: 0x0020 : cf 36 f3 69 36 93 69 38 49 c0 63 fb a0 2c 49 e3
Dec 23 13:26:10 kernel: 0x0030 : a7 ce 91 cb 12 ad 44 43 fb 57 cc 44 88 db 1f a5
Dec 23 13:26:10 kernel: 0x0040 : 35 de 24 1e cf ed 01 5e e0 e0 cc 0a
Dec 23 13:36:31 kernel: Received RSNIE in Assoc-Req: c015065f, len = 22
Dec 23 13:36:31 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 13:36:31 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 13:36:31 kernel: PMK: c0136261, len = 32
Dec 23 13:36:31 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 13:36:31 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 13:36:31 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 13:36:31 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 59 4a 59 cf
Dec 23 13:36:31 kernel: 0x0010 : 67 51 3d ac 91 2f 18 98 c9 12 30 95 ab 54 19 aa
Dec 23 13:36:31 kernel: 0x0020 : 39 49 d6 e0 82 4e 57 b8 19 55 9e 29 e3 48 34 85
Dec 23 13:36:31 kernel: 0x0030 : a4 29 de b2 14 d4 4d 4e 95 88 ac 45 c4 54 45 4d
Dec 23 13:36:31 kernel: 0x0040 : d5 92 53 6a 36 af 6a f3 57 9d bc ed
Dec 23 13:43:11 kernel: !!! (0) Can't allocate reordering mpdu blk
Dec 23 13:44:15 kernel: Received RSNIE in Assoc-Req: c0156677, len = 22
Dec 23 13:44:15 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 13:44:15 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 13:44:15 kernel: PMK: c0136261, len = 32
Dec 23 13:44:15 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 13:44:15 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 13:44:15 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 13:44:15 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 76 34 b1 a0
Dec 23 13:44:15 kernel: 0x0010 : e5 f9 5f 91 fc 8b c8 ba 8b ae ba e7 28 c1 73 ed
Dec 23 13:44:15 kernel: 0x0020 : c1 2b ed 4d 95 95 59 5d 95 d0 a2 f3 c4 23 a4 a0
Dec 23 13:44:15 kernel: 0x0030 : 53 44 2d a0 62 db 70 13 4d 67 66 2a 3e 99 0f 9f
Dec 23 13:44:15 kernel: 0x0040 : a4 cf 6e 5a 9d 76 18 f6 e7 26 9b 17
Dec 23 13:46:03 kernel: Received RSNIE in Assoc-Req: c0152ccf, len = 22
Dec 23 13:46:03 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 13:46:03 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 13:46:03 kernel: PMK: c0136261, len = 32
Dec 23 13:46:03 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 13:46:03 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 13:46:03 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 13:46:04 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 05 8d a7 20
Dec 23 13:46:04 kernel: 0x0010 : 8d f0 df 0a 07 ac 7a c2 53 d6 61 4e f5 89 a7 63
Dec 23 13:46:04 kernel: 0x0020 : 76 30 4e 78 8c 39 c3 91 c6 e8 37 42 90 e0 c4 e7
Dec 23 13:46:04 kernel: 0x0030 : d0 dd 90 3a a1 21 84 52 68 ff f7 c6 43 73 50 fc
Dec 23 13:46:04 kernel: 0x0040 : 0f 6b 8a c7 ea ee d1 86 63 33 5d 92
Dec 23 14:00:02 kernel: Received RSNIE in Assoc-Req: c0152667, len = 22
Dec 23 14:00:02 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 14:00:02 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 14:00:02 kernel: PMK: c0136261, len = 32
Dec 23 14:00:02 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 14:00:02 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 14:00:02 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 14:00:02 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 70 b1 85 8f
Dec 23 14:00:02 kernel: 0x0010 : 58 f5 8f 50 85 79 d4 37 bc 80 37 f8 40 38 fe 3e
Dec 23 14:00:02 kernel: 0x0020 : 1c 18 3e 7c 0c 1a 60 d5 0d 52 d5 2c e7 1a ab e5
Dec 23 14:00:02 kernel: 0x0030 : e8 81 c3 08 60 dc 5a 95 0f c8 a3 02 71 94 91 b9
Dec 23 14:00:02 kernel: 0x0040 : d1 54 63 85 90 c3 00 8f c4 37 93 3b
Dec 23 14:11:05 kernel: Received RSNIE in Assoc-Req: c0153337, len = 22
Dec 23 14:11:05 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 14:11:05 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 14:11:05 kernel: PMK: c0136261, len = 32
Dec 23 14:11:05 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 14:11:05 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 14:11:05 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 14:11:05 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 8c 87 64 39
Dec 23 14:11:05 kernel: 0x0010 : bc 6e 39 1a 37 2e b9 70 68 ff 8f ff 7f ff ff ff
Dec 23 14:11:05 kernel: 0x0020 : 00 07 00 70 fc 78 38 7f 78 06 80 6d cc 3e a0 d2
Dec 23 14:11:05 kernel: 0x0030 : 17 13 40 da 61 e7 c6 59 90 27 e7 d2 4d 61 24 f0
Dec 23 14:11:05 kernel: 0x0040 : 33 a5 99 e7 95 31 2b 94 19 a4 3f ba
Dec 23 14:12:04 kernel: Received RSNIE in Assoc-Req: c015466f, len = 22
Dec 23 14:12:04 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 14:12:04 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 14:12:04 kernel: PMK: c0136261, len = 32
Dec 23 14:12:04 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 14:12:04 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 14:12:04 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 14:12:04 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 87 16 02 96
Dec 23 14:12:04 kernel: 0x0010 : 49 2f 39 00 47 2e 5f f7 b3 b8 16 95 05 4b 6f 29
Dec 23 14:12:04 kernel: 0x0020 : db 3a 0d 55 92 c8 73 d4 c3 0d 5b 51 ba df d6 fc
Dec 23 14:12:04 kernel: 0x0030 : 6f c0 03 fb e0 22 02 21 dd e5 de 52 f2 90 29 01
Dec 23 14:12:04 kernel: 0x0040 : 6f ee fe e3 08 e3 71 ce e3 17 ce 8a
Dec 23 14:16:35 kernel: Received RSNIE in Assoc-Req: c014f98f, len = 22
Dec 23 14:16:35 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 14:16:35 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 14:16:36 kernel: PMK: c0136261, len = 32
Dec 23 14:16:36 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 14:16:36 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 14:16:36 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 14:16:36 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 d0 d0 0d 05
Dec 23 14:16:36 kernel: 0x0010 : 68 2b 82 b1 2b 1d b1 dc 71 1c ee 39 1c 6d c6 d7
Dec 23 14:16:36 kernel: 0x0020 : 36 be 94 1c be 3a 1c 5c 1d 1d 2e 22 f9 b4 85 ef
Dec 23 14:16:36 kernel: 0x0030 : 50 a0 2b 55 cf d3 03 12 91 eb 27 07 53 f4 62 67
Dec 23 14:16:36 kernel: 0x0040 : bc 0b 4d 2b bb c1 8d 5f 0e 58 07 a8
Dec 23 14:21:25 kernel: Received RSNIE in Assoc-Req: c0152667, len = 22
Dec 23 14:21:25 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 14:21:25 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 14:21:25 kernel: PMK: c0136261, len = 32
Dec 23 14:21:25 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 14:21:25 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 14:21:25 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 14:21:25 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 03 81 c7 e9
Dec 23 14:21:25 kernel: 0x0010 : 7e 9d 0b 11 4e eb 11 4b 14 b7 a5 be a4 11 41 18
Dec 23 14:21:25 kernel: 0x0020 : 11 8d 8c 6d 39 29 92 91 94 88 5b bf 1e fa 07 09
Dec 23 14:21:25 kernel: 0x0030 : 10 67 79 7c 24 5a 8e 6a f1 22 2f 09 2d 6c 9d 7b
Dec 23 14:21:25 kernel: 0x0040 : 12 b7 9f 6e 12 12 3a 09 c5 05 81 bf
Dec 23 14:25:37 kernel: Received RSNIE in Assoc-Req: c0156cdf, len = 22
Dec 23 14:25:37 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 14:25:37 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 14:25:38 kernel: PMK: c0136261, len = 32
Dec 23 14:25:38 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 14:25:38 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 14:25:38 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 14:25:38 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 bd c7 c7 5d
Dec 23 14:25:38 kernel: 0x0010 : 64 36 52 13 a3 9a 13 a5 04 e9 e6 21 f4 cb 80 7f
Dec 23 14:25:38 kernel: 0x0020 : e0 78 80 da 82 31 1f 2e 4f 36 88 ab fc b4 1a 5c
Dec 23 14:25:38 kernel: 0x0030 : 5a 3e 5c 1c e0 e1 f8 f7 8f 70 f7 0e 47 8c 3c 66
Dec 23 14:25:38 kernel: 0x0040 : 39 9c 66 32 ce 69 8c b7 34 8a 48 a5
Dec 23 14:31:45 kernel: Received RSNIE in Assoc-Req: c0153337, len = 22
Dec 23 14:31:45 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 14:31:45 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 14:31:45 kernel: PMK: c0136261, len = 32
Dec 23 14:31:45 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 14:31:45 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 14:31:45 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 14:31:45 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 2e 70 4c 89
Dec 23 14:31:45 kernel: 0x0010 : da 59 71 f9 95 51 4e b6 f5 c8 6f cf 33 40 c4 3b
Dec 23 14:31:45 kernel: 0x0020 : 35 05 10 4b 32 4d c9 38 f9 56 2c 91 3c c1 cc 19
Dec 23 14:31:45 kernel: 0x0030 : c1 90 f3 7f c8 0c 7f 3b 0c 43 62 1b 21 bb 1b bc
Dec 23 14:31:45 kernel: 0x0040 : 44 3f 21 fc e0 31 fc e1 ce 14 70 a5
Dec 23 14:42:05 kernel: Received RSNIE in Assoc-Req: c014f327, len = 22
Dec 23 14:42:05 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 14:42:05 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 14:42:05 kernel: PMK: c0136261, len = 32
Dec 23 14:42:05 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 14:42:05 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 14:42:05 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 14:42:05 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 16 88 4b be
Dec 23 14:42:05 kernel: 0x0010 : bb eb be bc 14 3e a1 f3 e0 cd 0c d6 cd 60 94 fb
Dec 23 14:42:05 kernel: 0x0020 : 4f b8 04 79 b8 61 c3 08 cf 7e f7 ef 40 0a cb 32
Dec 23 14:42:05 kernel: 0x0030 : 20 19 1f d9 38 b7 e9 09 b0 2a fd 05 76 de e1 01
Dec 23 14:42:05 kernel: 0x0040 : 64 ce 8c 8e fd 90 a2 00 07 d4 ee fc
Dec 23 14:43:08 kernel: Received RSNIE in Assoc-Req: c0156677, len = 22
Dec 23 14:43:08 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 14:43:08 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 14:43:08 kernel: PMK: c0136261, len = 32
Dec 23 14:43:08 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 14:43:08 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 14:43:08 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 14:43:08 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 83 02 30 2b
Dec 23 14:43:08 kernel: 0x0010 : 81 58 15 81 a7 eb 7e b4 0a 5f a5 fe a0 1d fe 2a
Dec 23 14:43:08 kernel: 0x0020 : 0e aa 15 59 55 93 a6 c3 36 19 9e 6c a9 43 18 31
Dec 23 14:43:08 kernel: 0x0030 : 5b b1 1e f3 3c 36 cd d1 be dd 3b 8b 5f 9b f2 f3
Dec 23 14:43:08 kernel: 0x0040 : 38 85 79 eb 5f 83 39 2b f6 33 90 55
Dec 23 14:43:12 kernel: !!! (0) Can't allocate reordering mpdu blk
Dec 23 14:52:25 kernel: Received RSNIE in Assoc-Req: c0154007, len = 22
Dec 23 14:52:25 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 14:52:25 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 14:52:25 kernel: PMK: c0136261, len = 32
Dec 23 14:52:25 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 14:52:25 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 14:52:25 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 14:52:25 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 0d 11 68 8c
Dec 23 14:52:25 kernel: 0x0010 : bb 99 b9 99 99 92 33 69 64 b1 b4 e8 4e 8f 74 7f
Dec 23 14:52:25 kernel: 0x0020 : 47 f0 7f 0a 0f 54 7a a2 55 dd 5d dd 8d 8d 5b 41
Dec 23 14:52:25 kernel: 0x0030 : ab 34 b3 d0 1c 91 b1 0e 30 db 19 41 21 d0 55 86
Dec 23 14:52:25 kernel: 0x0040 : 9b fa 7d a2 81 af e5 4a 62 4d 9b a4
Dec 23 15:00:00 kernel: Received RSNIE in Assoc-Req: c0156cdf, len = 22
Dec 23 15:00:00 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 15:00:00 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 15:00:00 kernel: PMK: c0136261, len = 32
Dec 23 15:00:00 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 15:00:00 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 15:00:00 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 15:00:00 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 a2 fd f7 1d
Dec 23 15:00:00 kernel: 0x0010 : 31 0c 6f 41 98 0a 10 69 f9 03 f5 2e 2c c6 7f e8
Dec 23 15:00:00 kernel: 0x0020 : e2 6a b3 88 fc f0 68 97 d6 86 35 4e f3 a4 9d 25
Dec 23 15:00:00 kernel: 0x0030 : e9 2d 6d 28 2d 70 94 7e 5c 0a 3f 57 f5 75 54 54
Dec 23 15:00:00 kernel: 0x0040 : 5d 5a 2a 54 5a b7 2a 44 52 27 dd 85
Dec 23 15:02:45 kernel: Received RSNIE in Assoc-Req: c0152ccf, len = 22
Dec 23 15:02:45 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 15:02:45 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 15:02:45 kernel: PMK: c0136261, len = 32
Dec 23 15:02:45 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 15:02:45 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 15:02:45 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 15:02:45 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 31 31 ce 70
Dec 23 15:02:45 kernel: 0x0010 : 0f a3 4e 4f c7 7c 64 8c 7c 79 bf 0c 06 3e cf 37
Dec 23 15:02:45 kernel: 0x0020 : eb aa 6e fb 7a a4 7f 1b 51 31 00 6b 4b a3 ba 30
Dec 23 15:02:45 kernel: 0x0030 : a3 02 18 13 7e c1 13 e6 3e 69 0c b5 34 ac 4a c3
Dec 23 15:02:45 kernel: 0x0040 : ac 3b 9e 20 1d f8 20 70 07 07 38 3a
Dec 23 15:08:00 kernel: Received RSNIE in Assoc-Req: c015600f, len = 22
Dec 23 15:08:00 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 15:08:00 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 15:08:01 kernel: PMK: c0136261, len = 32
Dec 23 15:08:01 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 15:08:01 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 15:08:01 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 15:08:01 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 24 8e db 88
Dec 23 15:08:01 kernel: 0x0010 : 47 7a 88 5b 7a 42 2d ea 21 5f ea 0a a0 a9 05 49
Dec 23 15:08:01 kernel: 0x0020 : ab 6d b6 db 6d b1 92 71 d8 e6 71 9a ce 65 7f 75
Dec 23 15:08:01 kernel: 0x0030 : c7 ed 42 28 92 63 3b 59 e5 ca eb 92 ab de c1 35
Dec 23 15:08:01 kernel: 0x0040 : d0 c1 72 a7 c3 a1 73 3f 5f 16 54 46
Dec 23 15:09:02 kernel: Received RSNIE in Assoc-Req: c0152ccf, len = 22
Dec 23 15:09:02 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 15:09:02 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 15:09:03 kernel: PMK: c0136261, len = 32
Dec 23 15:09:03 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 15:09:03 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 15:09:03 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 15:09:03 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 71 c5 1c 52
Dec 23 15:09:03 kernel: 0x0010 : c5 25 52 5c 6d 1e 2e 18 1e 70 18 fe c7 f0 7f 04
Dec 23 15:09:03 kernel: 0x0020 : 0f ba 04 53 22 9a 29 a6 65 9a 2c d2 ec 87 d6 70
Dec 23 15:09:03 kernel: 0x0030 : 19 24 ca dd b1 02 c5 9d 23 2c 68 a4 a8 0c 00 2a
Dec 23 15:09:03 kernel: 0x0040 : 05 70 02 c0 20 0f 45 3e 09 dd c1 8f
Dec 23 15:12:51 kernel: Received RSNIE in Assoc-Req: c0154cd7, len = 22
Dec 23 15:12:51 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 15:12:51 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 15:12:52 kernel: PMK: c0136261, len = 32
Dec 23 15:12:52 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 15:12:52 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 15:12:52 kernel: concatenation=: 802c1b08, len = 76
Dec 23 15:12:52 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 a6 73 b6 44
Dec 23 15:12:52 kernel: 0x0010 : ef 9c 6e 9a 6f b9 e7 27 75 68 70 ac 8e 38 93 b6
Dec 23 15:12:52 kernel: 0x0020 : a6 e7 00 87 58 df 2b ca c6 10 60 20 cd b3 6d 9b
Dec 23 15:12:52 kernel: 0x0030 : d9 b9 32 34 91 a6 1a 62 2c ea ce ab 75 5b 55 23
Dec 23 15:12:52 kernel: 0x0040 : 52 38 6e 3d 1c 28 1e bc f5 e3 5e 39
Dec 23 15:19:50 kernel: Received RSNIE in Assoc-Req: c0151997, len = 22
Dec 23 15:19:50 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 15:19:50 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 15:19:50 kernel: PMK: c0136261, len = 32
Dec 23 15:19:50 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 15:19:50 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 15:19:50 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 15:19:50 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 3e 69 f3 4c
Dec 23 15:19:50 kernel: 0x0010 : 65 9c a6 3e 63 eb e0 a4 fa dd 52 25 22 52 12 91
Dec 23 15:19:50 kernel: 0x0020 : d6 e4 91 b3 e4 c0 d9 fb 9f b1 fb 1f 59 6a 31 55
Dec 23 15:19:50 kernel: 0x0030 : 4d c7 37 d3 69 d0 71 98 a2 73 98 47 58 9f cb 63
Dec 23 15:19:50 kernel: 0x0040 : 40 e0 ba 94 00 ed 7e ed e8 f3 8a cd
Dec 23 15:30:09 kernel: Received RSNIE in Assoc-Req: c0152667, len = 22
Dec 23 15:30:09 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 15:30:09 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 15:30:09 kernel: PMK: c0136261, len = 32
Dec 23 15:30:09 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 15:30:09 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 15:30:09 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 15:30:09 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 86 54 65 45
Dec 23 15:30:09 kernel: 0x0010 : 54 56 5d 4d 2b 2b b2 b7 d4 80 a4 01 40 11 fe e3
Dec 23 15:30:09 kernel: 0x0020 : 11 cd 8e 6a e6 a0 95 fe a0 15 00 a9 ec c0 8e 61
Dec 23 15:30:09 kernel: 0x0030 : d3 0c 3c 33 69 75 51 fa d0 b7 c9 c5 46 cf d9 e1
Dec 23 15:30:09 kernel: 0x0040 : a9 66 8b 52 35 a5 47 d2 71 50 c0 b2
Dec 23 15:34:40 kernel: Received RSNIE in Assoc-Req: c0150cc7, len = 22
Dec 23 15:34:40 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 15:34:40 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 15:34:40 kernel: PMK: c0136261, len = 32
Dec 23 15:34:40 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 15:34:40 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 15:34:40 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 15:34:40 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 55 f2 5f 25
Dec 23 15:34:40 kernel: 0x0010 : f2 53 6d 61 d6 12 61 2f 12 fb 97 db 82 47 db 86
Dec 23 15:34:40 kernel: 0x0020 : b8 69 c3 4d cb 25 4d a4 25 b9 d2 36 f5 e6 a8 a1
Dec 23 15:34:40 kernel: 0x0030 : 19 15 86 54 5e 4c 0c 3e 4c 29 05 7d 00 ec f7 bb
Dec 23 15:34:40 kernel: 0x0040 : 17 8b 5c 7f 79 1d a4 f4 8b 4b 30 84
Dec 23 15:35:01 kernel: Received RSNIE in Assoc-Req: c014f327, len = 22
Dec 23 15:35:01 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 15:35:01 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 15:35:01 kernel: PMK: c0136261, len = 32
Dec 23 15:35:01 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 15:35:01 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 15:35:01 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 15:35:01 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 15 ae 85 35
Dec 23 15:35:01 kernel: 0x0010 : 19 16 d4 e6 75 28 65 e5 ac 24 2a 21 84 eb da 04
Dec 23 15:35:01 kernel: 0x0020 : ab 61 7b 13 e3 87 b9 a9 65 7c 03 ca 8f 37 0c 84
Dec 23 15:35:01 kernel: 0x0030 : 37 b9 bd c9 23 6d c9 25 b6 d3 b6 9d 96 23 9d cc
Dec 23 15:35:01 kernel: 0x0040 : 11 9d 8c e8 ce 87 17 8b bc 5f 1d 06
Dec 23 15:35:35 kernel: Received RSNIE in Assoc-Req: c0152667, len = 22
Dec 23 15:35:35 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 15:35:35 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 15:35:35 kernel: PMK: c0136261, len = 32
Dec 23 15:35:35 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 15:35:35 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 15:35:35 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 15:35:35 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 1a a8 aa 80
Dec 23 15:35:35 kernel: 0x0010 : 57 fe bf f4 00 59 fa 6f 59 0e 37 88 87 71 88 ef
Dec 23 15:35:35 kernel: 0x0020 : 8e f1 77 89 87 6e 76 e7 91 8c 8c 62 c3 44 44 e5
Dec 23 15:35:35 kernel: 0x0030 : f9 e5 7a 69 35 7c 1c 0d 46 0a 5f e3 a6 87 9f 20
Dec 23 15:35:35 kernel: 0x0040 : 52 41 05 7a 05 19 1d d9 0e 93 a4 88
Dec 23 15:37:52 kernel: Received RSNIE in Assoc-Req: c01559a7, len = 22
Dec 23 15:37:52 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 15:37:52 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 15:37:53 kernel: PMK: c0136261, len = 32
Dec 23 15:37:53 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 15:37:53 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 15:37:53 kernel: concatenation=: 802c1b08, len = 76
Dec 23 15:37:53 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 12 1f bc ec
Dec 23 15:37:53 kernel: 0x0010 : 2c 27 13 f6 37 b9 b4 fa 9a fb c5 cf 49 81 f9 fc
Dec 23 15:37:53 kernel: 0x0020 : f6 d4 cd 39 8d df f5 38 62 2e fc db ec 84 37 bf
Dec 23 15:37:53 kernel: 0x0030 : bd ff ef fe 7f f6 ff b5 fb 5c da e5 d7 2a 46 ab
Dec 23 15:37:53 kernel: 0x0040 : 35 59 55 91 ac 88 9b b9 dd cf 11 84
Dec 23 15:43:13 kernel: !!! (0) Can't allocate reordering mpdu blk
Dec 23 15:50:05 kernel: Received RSNIE in Assoc-Req: c0151997, len = 22
Dec 23 15:50:05 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 15:50:05 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 15:50:05 kernel: PMK: c0136261, len = 32
Dec 23 15:50:05 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 15:50:05 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 15:50:05 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 15:50:05 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 9d d5 a8 48
Dec 23 15:50:05 kernel: 0x0010 : 36 9f 20 cf 79 1d f3 3d 10 78 87 31 68 de b7 16
Dec 23 15:50:05 kernel: 0x0020 : 57 b0 3d 3f d7 00 93 08 f8 31 14 0a cf 87 f8 79
Dec 23 15:50:05 kernel: 0x0030 : 87 91 c3 70 c8 fb 8f b0 7d 85 ec 2b 3d 4b 2b 45
Dec 23 15:50:05 kernel: 0x0040 : a5 d7 2e ba 14 5a 45 aa 2d 56 95 4e
Dec 23 15:54:41 kernel: Received RSNIE in Assoc-Req: c015065f, len = 22
Dec 23 15:54:41 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 15:54:41 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 15:54:41 kernel: PMK: c0136261, len = 32
Dec 23 15:54:41 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 15:54:41 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 15:54:41 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 15:54:41 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 48 f7 8f 76
Dec 23 15:54:41 kernel: 0x0010 : f7 69 76 9c b4 e3 4e 33 e3 3d 33 dc 9e e1 11 e5
Dec 23 15:54:41 kernel: 0x0020 : 1e 56 1a 93 2b 66 b6 6e 99 12 37 68 9a 07 68 34
Dec 23 15:54:41 kernel: 0x0030 : be 9c 5c cc ca a3 a6 52 91 a8 52 8f d8 40 f9 70
Dec 23 15:54:41 kernel: 0x0040 : 45 6c 4b 5c 31 af 59 61 dd d0 80 35
Dec 23 15:58:51 kernel: Received RSNIE in Assoc-Req: c015533f, len = 22
Dec 23 15:58:51 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 15:58:51 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 15:58:51 kernel: PMK: c0136261, len = 32
Dec 23 15:58:51 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 15:58:51 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 15:58:51 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 15:58:51 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 6e a9 73 ba
Dec 23 15:58:51 kernel: 0x0010 : de da 19 9f 75 91 85 cb 49 5a b9 87 60 15 65 de
Dec 23 15:58:51 kernel: 0x0020 : 0c 99 94 b7 bf d4 48 ee 64 8a 04 19 90 05 80 2e
Dec 23 15:58:51 kernel: 0x0030 : fd 14 d1 45 8a 28 ae b9 14 60 b9 f4 30 58 7d 3c
Dec 23 15:58:51 kernel: 0x0040 : d3 c8 3c 8b e4 5d 22 e9 2e 9c e9 c4
Dec 23 16:00:25 kernel: Received RSNIE in Assoc-Req: c0154cd7, len = 22
Dec 23 16:00:25 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:00:25 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 16:00:25 kernel: PMK: c0136261, len = 32
Dec 23 16:00:25 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:00:25 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:00:25 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 16:00:25 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 73 17 ce 82
Dec 23 16:00:25 kernel: 0x0010 : e8 26 be cb 13 44 cb b5 a2 54 12 a0 d5 f1 5f 1e
Dec 23 16:00:25 kernel: 0x0020 : 07 09 38 4e 7b 16 4e 9c 74 e6 a7 30 7e bd ef e5
Dec 23 16:00:25 kernel: 0x0030 : 59 1d 93 e4 cc e6 f2 ed e4 38 4e 31 83 35 cc 69
Dec 23 16:00:25 kernel: 0x0040 : c8 f8 f8 73 0e 87 1c e1 d0 ca 52 b1
Dec 23 16:02:39 kernel: Received RSNIE in Assoc-Req: c0151fff, len = 22
Dec 23 16:02:39 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:02:39 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 16:02:40 kernel: PMK: c0136261, len = 32
Dec 23 16:02:40 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:02:40 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:02:40 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 16:02:40 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 45 a7 d2 c0
Dec 23 16:02:40 kernel: 0x0010 : 69 fe 60 1f fe 00 f0 06 7f cf 03 00 30 09 80 4c
Dec 23 16:02:40 kernel: 0x0020 : 04 c2 b3 db 3d b7 ed be db e0 41 f3 4e be aa f9
Dec 23 16:02:40 kernel: 0x0030 : dc a7 47 bf 63 8d bc 61 c1 d8 cc 0a 95 98 6e 84
Dec 23 16:02:40 kernel: 0x0040 : 37 d5 c3 d6 5b f7 bf f4 8c 55 d3 a6
Dec 23 16:06:04 kernel: Received RSNIE in Assoc-Req: c0153337, len = 22
Dec 23 16:06:04 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:06:04 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 16:06:04 kernel: PMK: c0136261, len = 32
Dec 23 16:06:04 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:06:04 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:06:04 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 16:06:04 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 74 71 e4 00
Dec 23 16:06:04 kernel: 0x0010 : 91 4c a5 63 c5 bb da 23 89 d3 61 29 7b 76 fb c1
Dec 23 16:06:04 kernel: 0x0020 : 04 59 24 59 d7 7d 9a d2 1c b4 a5 c4 da b1 ab 15
Dec 23 16:06:04 kernel: 0x0030 : b1 56 75 4d 54 df b2 07 20 74 fc 5b 3a 48 a4 8a
Dec 23 16:06:04 kernel: 0x0040 : 48 a8 ba bf 54 0c 40 c3 f3 cb 9e 5e
Dec 23 16:09:27 kernel: Received RSNIE in Assoc-Req: c01559a7, len = 22
Dec 23 16:09:27 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:09:27 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 16:09:28 kernel: PMK: c0136261, len = 32
Dec 23 16:09:28 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:09:28 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:09:28 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 16:09:28 kernel: 0x0000 : 10 bf 48 81 b5 68 d0 23 db 52 bd f7 1b b7 2a 30
Dec 23 16:09:28 kernel: 0x0010 : 9e cc 26 b8 09 dc ba 26 37 be 56 7e d0 78 15 a3
Dec 23 16:09:28 kernel: 0x0020 : 1a 2a 3f 33 e5 b2 41 98 7d c5 a4 57 75 49 54 9d
Dec 23 16:09:28 kernel: 0x0030 : b6 22 b1 11 ee e4 ee 41 72 0b 6f a2 fa 2f 5d 06
Dec 23 16:09:28 kernel: 0x0040 : e8 30 41 86 18 68 79 7d cb ee 5f 73
Dec 23 16:16:35 kernel: Received RSNIE in Assoc-Req: c01559a7, len = 22
Dec 23 16:16:35 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:16:35 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 16:16:35 kernel: PMK: c0136261, len = 32
Dec 23 16:16:35 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:16:35 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:16:35 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 16:16:35 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 73 c6 37 c7
Dec 23 16:16:35 kernel: 0x0010 : 1f c5 dc 60 d2 7f 02 d1 fc 0a 22 c0 ae 3d 82 37
Dec 23 16:16:35 kernel: 0x0020 : 5c 29 bb 8a a7 9f 2a 59 88 b5 1c 98 c7 28 39 41
Dec 23 16:16:35 kernel: 0x0030 : ca 0c a0 cd f3 22 99 12 37 6a 76 a8 95 73 ab 99
Dec 23 16:16:35 kernel: 0x0040 : a3 30 cc fb 30 44 7d db dd b2 24 d5
Dec 23 16:18:18 kernel: Received RSNIE in Assoc-Req: c0151fff, len = 22
Dec 23 16:18:18 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:18:18 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 16:18:18 kernel: PMK: c0136261, len = 32
Dec 23 16:18:18 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:18:18 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:18:18 kernel: concatenation=: 802c1b08, len = 76
Dec 23 16:18:18 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 47 62 3b 12
Dec 23 16:18:18 kernel: 0x0010 : d8 94 76 b7 4a 44 52 20 6e f9 88 33 83 3d 19 eb
Dec 23 16:18:18 kernel: 0x0020 : 30 a6 85 32 29 90 66 f3 37 9b 43 22 c9 ee b8 d2
Dec 23 16:18:18 kernel: 0x0030 : 5a cd 19 82 e8 74 52 b8 14 dc 07 17 5c 37 dc 42
Dec 23 16:18:18 kernel: 0x0040 : c7 80 76 f1 b6 8d d9 66 17 56 ce d6
Dec 23 16:26:55 kernel: Received RSNIE in Assoc-Req: c0152ccf, len = 22
Dec 23 16:26:55 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:26:55 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 16:26:55 kernel: PMK: c0136261, len = 32
Dec 23 16:26:55 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:26:55 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:26:55 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 16:26:55 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 d4 e0 24 c6
Dec 23 16:26:55 kernel: 0x0010 : 06 ce 33 d2 20 76 23 9d d4 4f 30 b9 bd 06 be bc
Dec 23 16:26:55 kernel: 0x0020 : f4 07 a7 da fd 72 95 57 1f 36 0d 58 db b1 44 e6
Dec 23 16:26:55 kernel: 0x0030 : 27 34 8c bc cb c7 43 86 e3 cb 3c b2 cb 23 4d cf
Dec 23 16:26:55 kernel: 0x0040 : 91 85 18 53 7a c5 ac 5b 9d 24 2d bd
Dec 23 16:29:35 kernel: Received RSNIE in Assoc-Req: c0155347, len = 22
Dec 23 16:29:35 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:29:35 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 23 16:29:36 kernel: PMK: c0136261, len = 32
Dec 23 16:29:36 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:29:36 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:29:36 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 16:29:36 kernel: 0x0000 : 10 bf 48 81 b5 68 88 30 8a 49 26 9c 53 b0 74 9f
Dec 23 16:29:36 kernel: 0x0010 : 72 57 34 95 c9 37 90 1f d8 23 dc 28 4f c8 84 fa
Dec 23 16:29:36 kernel: 0x0020 : 92 0f 52 a0 a8 f9 d4 b9 e6 13 a2 d1 68 7d 71 ff
Dec 23 16:29:36 kernel: 0x0030 : 70 4c fe 9b 63 f6 67 fe 89 d0 6c e9 6e 0b 1b 71
Dec 23 16:29:36 kernel: 0x0040 : 48 13 45 bc 44 d7 c6 79 c3 26 0f bb
Dec 23 16:33:30 kernel: Received RSNIE in Assoc-Req: c015600f, len = 22
Dec 23 16:33:30 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:33:30 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 16:33:30 kernel: PMK: c0136261, len = 32
Dec 23 16:33:30 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:33:30 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:33:30 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 16:33:30 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 d4 67 a3 3f
Dec 23 16:33:30 kernel: 0x0010 : cc 0d c0 d6 f9 49 35 b5 a4 a3 b5 c3 ae 1b 1e 4f
Dec 23 16:33:30 kernel: 0x0020 : e4 fd 4f d6 81 4c eb 3e 4c 1e c1 ea fa 31 bb f3
Dec 23 16:33:30 kernel: 0x0030 : 27 c3 77 0f 54 05 ac 05 1f 71 ad bc c2 c8 d9 19
Dec 23 16:33:30 kernel: 0x0040 : 05 42 3d 35 59 3a a6 27 ce 05 34 70
Dec 23 16:36:26 kernel: Received RSNIE in Assoc-Req: c014fff7, len = 22
Dec 23 16:36:26 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:36:26 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 16:36:27 kernel: PMK: c0136261, len = 32
Dec 23 16:36:27 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:36:27 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:36:27 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 16:36:27 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 48 a3 7a f2
Dec 23 16:36:27 kernel: 0x0010 : cf c8 ef 5a 90 0f 36 31 93 b5 bb 4e 2b ee 74 5b
Dec 23 16:36:27 kernel: 0x0020 : 19 cc 52 1e 5e b3 fe f3 40 0c 5a 6e e3 f0 e0 79
Dec 23 16:36:27 kernel: 0x0030 : f8 62 86 27 ce c5 89 d2 9d 22 d2 2b 91 59 8a c8
Dec 23 16:36:27 kernel: 0x0040 : 53 7a 37 a1 bd 08 e8 41 7b e3 be 3f
Dec 23 16:43:14 kernel: !!! (0) Can't allocate reordering mpdu blk
Dec 23 16:45:55 kernel: Received RSNIE in Assoc-Req: c0152ccf, len = 22
Dec 23 16:45:55 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:45:55 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 16:45:55 kernel: PMK: c0136261, len = 32
Dec 23 16:45:55 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:45:55 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:45:55 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 16:45:55 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 5a e4 ae 43
Dec 23 16:45:55 kernel: 0x0010 : 8d e3 21 c4 e3 b2 3b 2e d9 70 97 02 70 26 81 33
Dec 23 16:45:55 kernel: 0x0020 : f6 67 99 86 67 9f c3 03 18 1e 7e 13 7f 16 8c bb
Dec 23 16:45:55 kernel: 0x0030 : fd 42 4f eb 92 0d 72 77 d5 08 7e 7f 07 5e 5c 40
Dec 23 16:45:55 kernel: 0x0040 : 33 4f a8 4d 07 be 87 a4 54 89 0b 58
Dec 23 16:50:58 kernel: Received RSNIE in Assoc-Req: c0156677, len = 22
Dec 23 16:50:58 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:50:58 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 16:50:58 kernel: PMK: c0136261, len = 32
Dec 23 16:50:58 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:50:58 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:50:58 kernel: concatenation=: 802c1b08, len = 76
Dec 23 16:50:58 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 64 ba 25 d6
Dec 23 16:50:58 kernel: 0x0010 : d1 4f 14 f8 a7 c1 3e 0a 0f a9 7d 48 d4 88 a4 44
Dec 23 16:50:58 kernel: 0x0020 : 22 23 11 1e 88 f5 8f 5f 7a f9 28 34 d2 dc d4 0b
Dec 23 16:50:58 kernel: 0x0030 : 60 92 a4 d4 fd b8 c2 d0 82 5d c8 fd c2 82 f9 74
Dec 23 16:50:58 kernel: 0x0040 : 5a 59 9c 89 f2 8d 58 45 a7 e8 80 43
Dec 23 16:52:13 kernel: Received RSNIE in Assoc-Req: c0152ccf, len = 22
Dec 23 16:52:13 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:52:13 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 16:52:13 kernel: PMK: c0136261, len = 32
Dec 23 16:52:13 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:52:13 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:52:13 kernel: concatenation=: 802c1b08, len = 76
Dec 23 16:52:13 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 91 d2 d2 a0
Dec 23 16:52:13 kernel: 0x0010 : ed 7e 12 f7 82 4e 88 9e 7a fc af c9 dd 11 66 cb
Dec 23 16:52:13 kernel: 0x0020 : 2e 49 52 5b 53 38 ff 96 dc 4c 08 26 e5 ad 2d 6c
Dec 23 16:52:13 kernel: 0x0030 : 29 32 b6 6a 66 ac ca 9b ab 25 b2 53 92 9d 29 d0
Dec 23 16:52:13 kernel: 0x0040 : b1 7c 74 19 41 9a f3 2c 32 cd 96 6a
Dec 23 16:54:25 kernel: Received RSNIE in Assoc-Req: c0152667, len = 22
Dec 23 16:54:25 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:54:25 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 16:54:25 kernel: PMK: c0136261, len = 32
Dec 23 16:54:25 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:54:25 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:54:25 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 16:54:25 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 2a 40 5b fd
Dec 23 16:54:25 kernel: 0x0010 : bf d4 01 5d 0a e8 ae 8b 17 46 45 cc d1 98 19 81
Dec 23 16:54:25 kernel: 0x0020 : 67 e5 3f 2c 06 99 69 93 66 c8 36 47 33 d4 dd 2c
Dec 23 16:54:25 kernel: 0x0030 : 8f 5a a0 70 77 bb 38 20 48 a4 31 b0 57 ba 60 47
Dec 23 16:54:25 kernel: 0x0040 : 56 d2 72 29 07 98 51 a9 3d bf 28 33
Dec 23 16:56:25 kernel: Received RSNIE in Assoc-Req: c015533f, len = 22
Dec 23 16:56:25 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:56:25 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 16:56:25 kernel: PMK: c0136261, len = 32
Dec 23 16:56:25 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:56:25 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:56:25 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 16:56:25 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 aa ca 4b 32
Dec 23 16:56:25 kernel: 0x0010 : cc fb 66 7a 86 fe a3 82 18 98 e2 8d 2d 20 18 0c
Dec 23 16:56:25 kernel: 0x0020 : d8 f8 10 e0 75 48 5f 93 5a c8 28 48 fe ef ee f2
Dec 23 16:56:25 kernel: 0x0030 : ef 2f 79 7d 97 da 7d a6 ed 30 69 85 98 59 85 97
Dec 23 16:56:25 kernel: 0x0040 : d3 45 65 d0 5d 06 2f 93 83 62 1b 13
Dec 23 16:57:52 kernel: Received RSNIE in Assoc-Req: c0154cd7, len = 22
Dec 23 16:57:52 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 16:57:52 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 16:57:52 kernel: PMK: c0136261, len = 32
Dec 23 16:57:53 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 16:57:53 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 16:57:53 kernel: concatenation=: 802c1b08, len = 76
Dec 23 16:57:53 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 34 33 54 0e
Dec 23 16:57:53 kernel: 0x0010 : f7 76 86 d2 21 44 5c ce 07 be 24 25 a0 19 d0 63
Dec 23 16:57:53 kernel: 0x0020 : 1d d3 6a ca 2a 6d d5 01 99 9f 40 73 3e f2 10 da
Dec 23 16:57:53 kernel: 0x0030 : 79 2d c9 68 4b 40 a5 ff 5f fa ff d4 01 58 f5 3b
Dec 23 16:57:53 kernel: 0x0040 : a9 da 62 55 12 ab 95 5d 55 14 57 5e
Dec 23 17:06:45 kernel: Received RSNIE in Assoc-Req: c0151fff, len = 22
Dec 23 17:06:45 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 17:06:45 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 17:06:45 kernel: PMK: c0136261, len = 32
Dec 23 17:06:45 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 17:06:45 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 17:06:45 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 17:06:45 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 2e 8d 15 52
Dec 23 17:06:45 kernel: 0x0010 : 98 43 50 c7 7e b8 33 cb 87 5c 77 b9 43 75 cf 33
Dec 23 17:06:45 kernel: 0x0020 : 35 06 b3 f7 a9 33 09 dd 50 84 aa 77 2f 96 83 4f
Dec 23 17:06:45 kernel: 0x0030 : 34 f1 4f 1b 87 25 39 2a 6d 5a d5 af ad 7d 94 11
Dec 23 17:06:45 kernel: 0x0040 : 41 1a ee 5d 8d 14 68 a0 75 f7 5f 7c
Dec 23 17:12:37 kernel: Received RSNIE in Assoc-Req: c0156677, len = 22
Dec 23 17:12:37 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 17:12:37 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 17:12:37 kernel: PMK: c0136261, len = 32
Dec 23 17:12:37 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 17:12:37 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 17:12:37 kernel: concatenation=: 802c1b08, len = 76
Dec 23 17:12:37 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 02 15 ef 53
Dec 23 17:12:37 kernel: 0x0010 : 85 65 2b 2d 4d 2e 96 8d 4b 91 5c 8d e4 69 b9 6e
Dec 23 17:12:37 kernel: 0x0020 : cb 77 5b bd dd ee 10 8c 08 c3 46 1b 33 65 bf a6
Dec 23 17:12:37 kernel: 0x0030 : 88 ed 81 c7 3f d8 bb 50 5b 98 8b 2f 1e 2e fe ec
Dec 23 17:12:37 kernel: 0x0040 : 16 90 97 47 f1 85 0b 63 f7 63 4e 02
Dec 23 17:16:12 kernel: Received RSNIE in Assoc-Req: c014f327, len = 22
Dec 23 17:16:12 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 17:16:12 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 17:16:12 kernel: PMK: c0136261, len = 32
Dec 23 17:16:12 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 17:16:12 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 17:16:12 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 17:16:12 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 73 56 ca 95
Dec 23 17:16:12 kernel: 0x0010 : a9 51 4a 89 57 63 76 31 63 1c e7 19 71 98 e6 77
Dec 23 17:16:12 kernel: 0x0020 : 67 7d c4 12 41 23 ed cb dc b1 1a 71 7a 7b 02 4a
Dec 23 17:16:12 kernel: 0x0030 : ab 17 f4 8c 7e d6 81 43 9e 9c e7 3a b5 23 b1 b5
Dec 23 17:16:12 kernel: 0x0040 : cd 7e 6f d9 fe 09 ca 3e 12 6a b5 5b
Dec 23 17:18:09 kernel: Received RSNIE in Assoc-Req: c014f32d, len = 22
Dec 23 17:18:09 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 17:18:09 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 23 17:18:10 kernel: PMK: c0136261, len = 32
Dec 23 17:18:10 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 17:18:10 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 17:18:10 kernel: concatenation=: 802c1b08, len = 76
Dec 23 17:18:10 kernel: 0x0000 : 10 bf 48 81 b5 68 18 87 96 8f a1 f1 96 a3 70 d2
Dec 23 17:18:10 kernel: 0x0010 : c2 c0 7f 01 76 fc 87 a7 8e 54 4d 18 aa 1f cf b3
Dec 23 17:18:10 kernel: 0x0020 : 5a 67 b4 e0 6a e3 34 bf a3 b6 4e c5 9f 73 2b a7
Dec 23 17:18:10 kernel: 0x0030 : b9 b0 33 b0 b5 41 1f 60 ad 10 1b e3 8c f2 9b 31
Dec 23 17:18:10 kernel: 0x0040 : fa 77 d6 f1 e1 d7 e2 26 ac 04 63 d5
Dec 23 17:24:00 kernel: Received RSNIE in Assoc-Req: c015266d, len = 22
Dec 23 17:24:00 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 17:24:00 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 23 17:24:00 kernel: PMK: c0136261, len = 32
Dec 23 17:24:00 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 17:24:00 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 17:24:00 kernel: concatenation=: 802c1b08, len = 76
Dec 23 17:24:00 kernel: 0x0000 : 10 bf 48 81 b5 68 18 87 96 8f a1 f1 7d e1 9f d8
Dec 23 17:24:00 kernel: 0x0010 : 02 eb f6 bb fa e8 0c 94 05 c2 9e 39 e4 e4 76 26
Dec 23 17:24:00 kernel: 0x0020 : 93 1a 6c 2e 74 af 52 b7 f6 8a 0e af e1 ef e3 ac
Dec 23 17:24:00 kernel: 0x0030 : 6e e4 5b 00 61 34 09 d2 2e 6c d8 72 22 61 ba 5d
Dec 23 17:24:00 kernel: 0x0040 : 25 24 62 96 d2 49 51 2e 88 21 90 0f
Dec 23 17:26:40 kernel: Received RSNIE in Assoc-Req: c015065f, len = 22
Dec 23 17:26:40 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 17:26:40 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 17:26:40 kernel: PMK: c0136261, len = 32
Dec 23 17:26:40 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 17:26:40 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 17:26:40 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 17:26:40 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 0c b3 2b 06
Dec 23 17:26:40 kernel: 0x0010 : 80 04 be fc bf 7e 58 b5 bb 37 62 79 e2 ef 71 3b
Dec 23 17:26:40 kernel: 0x0020 : 65 8e 47 66 57 a6 bd c2 d1 8f 19 cf b4 33 5e 62
Dec 23 17:26:40 kernel: 0x0030 : 19 d2 62 d6 d2 92 6b 6a 49 5a 95 a8 5a 86 d4 34
Dec 23 17:26:40 kernel: 0x0040 : 43 48 cb 74 b7 49 ba 4a a4 ae b5 1d
Dec 23 17:27:13 kernel: Received RSNIE in Assoc-Req: c014fff7, len = 22
Dec 23 17:27:13 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 17:27:13 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 17:27:14 kernel: PMK: c0136261, len = 32
Dec 23 17:27:14 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 17:27:14 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 17:27:14 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 17:27:14 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 b8 a6 75 9f
Dec 23 17:27:14 kernel: 0x0010 : ac fd 67 ec 81 3e 13 e3 9f 18 f8 c2 73 d9 3d 97
Dec 23 17:27:14 kernel: 0x0020 : 13 41 65 f3 5f 3c f3 cd 61 94 0c a5 f0 f9 d0 dc
Dec 23 17:27:14 kernel: 0x0030 : 9d b7 cb d8 0e a5 d2 6e 63 c2 f7 43 37 22 b4 aa
Dec 23 17:27:14 kernel: 0x0040 : 4c c7 b0 af a4 20 b8 df 93 de e0 70
Dec 23 17:31:58 kernel: Received RSNIE in Assoc-Req: c0154cd7, len = 22
Dec 23 17:31:58 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 17:31:58 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 17:31:58 kernel: PMK: c0136261, len = 32
Dec 23 17:31:58 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 17:31:58 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 17:31:58 kernel: concatenation=: 802c1b08, len = 76
Dec 23 17:31:58 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 87 19 c7 33
Dec 23 17:31:58 kernel: 0x0010 : 73 30 99 83 98 3b c1 dd 0e ea 11 53 8a 9a a9 a5
Dec 23 17:31:58 kernel: 0x0020 : 4d 2a 96 ab 6a b6 55 b1 5b 14 d8 a3 b9 c9 6e 71
Dec 23 17:31:58 kernel: 0x0030 : b8 3a 1a 0b f4 50 74 b0 20 95 b2 98 c1 c0 48 2d
Dec 23 17:31:58 kernel: 0x0040 : f6 0d a5 b7 3a ee dc 7f 53 4d b3 03
Dec 23 17:32:26 kernel: Received RSNIE in Assoc-Req: c0156677, len = 22
Dec 23 17:32:26 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 17:32:26 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 17:32:26 kernel: PMK: c0136261, len = 32
Dec 23 17:32:26 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 17:32:26 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 17:32:26 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 17:32:26 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 44 36 bc 99
Dec 23 17:32:26 kernel: 0x0010 : 36 6b 99 4d ca 6d 59 25 92 53 da c2 d6 11 61 15
Dec 23 17:32:26 kernel: 0x0020 : ee a8 ea 8a ab af 45 0e af 1d 87 11 c9 b3 62 57
Dec 23 17:32:26 kernel: 0x0030 : 90 ac 45 d6 54 ae 38 3d c8 09 f5 03 e5 21 d7 ae
Dec 23 17:32:26 kernel: 0x0040 : 11 c3 d7 9a 3b fd e7 2b 0c 97 46 ac
Dec 23 17:43:05 kernel: Received RSNIE in Assoc-Req: c0154cd7, len = 22
Dec 23 17:43:05 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 17:43:05 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 17:43:05 kernel: PMK: c0136261, len = 32
Dec 23 17:43:05 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 17:43:05 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 17:43:05 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 17:43:05 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 2a 2a 5c f1
Dec 23 17:43:05 kernel: 0x0010 : 7f 32 20 ce 55 21 b4 e6 67 46 71 db bc dd cf 81
Dec 23 17:43:05 kernel: 0x0020 : d0 46 bc f3 79 39 87 ea 7c 8b 68 c8 b8 78 87 89
Dec 23 17:43:05 kernel: 0x0030 : 78 9f 3b 05 b0 53 05 30 53 05 67 d3 82 c4 d3 b7
Dec 23 17:43:05 kernel: 0x0040 : c4 87 db c0 bc 01 c0 1d fe 29 f1 4b
Dec 23 17:44:43 kernel: Received RSNIE in Assoc-Req: c0154007, len = 22
Dec 23 17:44:43 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 17:44:43 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 17:44:43 kernel: PMK: c0136261, len = 32
Dec 23 17:44:43 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 17:44:43 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 17:44:43 kernel: concatenation=: 802c1b08, len = 76
Dec 23 17:44:43 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 1a 08 2f bf
Dec 23 17:44:43 kernel: 0x0010 : 7d f9 20 62 03 16 ce 9e 74 f6 58 4c 7b 35 26 50
Dec 23 17:44:43 kernel: 0x0020 : 9a f8 28 38 be 3a 1c 5c 1d 1f 2e 0e 78 cf 18 35
Dec 23 17:44:43 kernel: 0x0030 : 53 70 1d fe 46 b5 8b 81 d8 bb 52 e3 5e 88 ad 8e
Dec 23 17:44:43 kernel: 0x0040 : f6 f9 fa 62 d4 5b 8d 6c 87 eb d5 4a
Dec 23 17:48:12 kernel: Received RSNIE in Assoc-Req: c015667d, len = 22
Dec 23 17:48:12 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 17:48:12 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 23 17:48:13 kernel: PMK: c0136261, len = 32
Dec 23 17:48:13 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 17:48:13 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 17:48:13 kernel: concatenation=: 802c1b08, len = 76
Dec 23 17:48:13 kernel: 0x0000 : 10 bf 48 81 b5 68 18 87 96 8f a1 f1 92 a0 88 0c
Dec 23 17:48:13 kernel: 0x0010 : 62 df a2 10 fe 72 9c 81 1a d6 a1 00 41 19 a4 a1
Dec 23 17:48:13 kernel: 0x0020 : 3d a7 0f f0 ea d3 d0 86 39 2e 79 a2 aa af 22 d0
Dec 23 17:48:13 kernel: 0x0030 : ba 88 6c 8b 8a 90 a9 cc 20 6e 8b 3f 7d 46 34 e8
Dec 23 17:48:13 kernel: 0x0040 : c1 d4 9d 67 02 1a f7 6e 21 f0 ae 93
Dec 23 17:53:25 kernel: Received RSNIE in Assoc-Req: c015466f, len = 22
Dec 23 17:53:25 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 17:53:25 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 17:53:25 kernel: PMK: c0136261, len = 32
Dec 23 17:53:25 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 17:53:25 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 17:53:25 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 17:53:25 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 18 e0 71 f3
Dec 23 17:53:25 kernel: 0x0010 : 8f 98 f9 8a 98 a7 8a 7e ac 0c 3f 32 0c d7 66 be
Dec 23 17:53:25 kernel: 0x0020 : ca 0c a0 c8 f3 78 9b c1 de 09 e0 9c cc cf af db
Dec 23 17:53:25 kernel: 0x0030 : 5d ac 07 2b ea 70 e0 32 ce 4d 1d 31 75 27 96 b0
Dec 23 17:53:25 kernel: 0x0040 : 97 6d fe 27 c5 a4 fc d6 93 74 80 3b
Dec 23 17:56:50 kernel: Received RSNIE in Assoc-Req: c01559a7, len = 22
Dec 23 17:56:50 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 17:56:50 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 17:56:51 kernel: PMK: c0136261, len = 32
Dec 23 17:56:51 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 17:56:51 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 17:56:51 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 17:56:51 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 68 5d 7a 22
Dec 23 17:56:51 kernel: 0x0010 : d1 17 11 79 e8 67 86 79 cc 36 3c 97 c9 75 68 a1
Dec 23 17:56:51 kernel: 0x0020 : ba f2 50 d8 f2 7b d8 4a c2 57 da 8a 87 88 41 f4
Dec 23 17:56:51 kernel: 0x0030 : e3 0d a2 7a c6 bf 92 98 59 ef 20 69 0b 93 73 58
Dec 23 17:56:51 kernel: 0x0040 : 86 e9 da ef 59 8e e9 d7 b6 e9 a6 29
Dec 23 18:03:45 kernel: Received RSNIE in Assoc-Req: c015466f, len = 22
Dec 23 18:03:45 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 18:03:45 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 18:03:45 kernel: PMK: c0136261, len = 32
Dec 23 18:03:45 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 18:03:45 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 18:03:45 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 18:03:45 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 8a 4e ad 88
Dec 23 18:03:45 kernel: 0x0010 : 27 74 77 46 8b 9b 5c d8 cd 89 27 65 c4 d6 d9 4f
Dec 23 18:03:45 kernel: 0x0020 : 94 f6 4f 6f 84 80 db f8 40 74 07 4e 92 41 87 0f
Dec 23 18:03:45 kernel: 0x0030 : 33 cf 7f e8 b3 e2 09 cd b3 a5 54 1e d0 07 6f ee
Dec 23 18:03:45 kernel: 0x0040 : 66 ed ef 77 17 72 69 86 66 4d 06 65
Dec 23 18:08:07 kernel: Received RSNIE in Assoc-Req: c0154007, len = 22
Dec 23 18:08:07 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 18:08:07 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 18:08:08 kernel: PMK: c0136261, len = 32
Dec 23 18:08:08 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 18:08:08 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 18:08:08 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 18:08:08 kernel: 0x0000 : 10 bf 48 81 b5 68 60 fa cd 40 67 b6 46 2f 9d 07
Dec 23 18:08:08 kernel: 0x0010 : d0 77 f8 8b c4 5e ba 1e a1 e9 e1 65 0b 29 b2 9e
Dec 23 18:08:08 kernel: 0x0020 : 29 ec 9e c7 f6 3a 9c 5c 3a 33 a3 3b 92 a4 e5 0a
Dec 23 18:08:08 kernel: 0x0030 : ca 83 a1 16 fd 04 90 9a 7d 0a 2e c1 9a f4 51 a7
Dec 23 18:08:08 kernel: 0x0040 : c2 a2 41 22 23 81 be aa c8 f3 ca 73
Dec 23 18:16:42 kernel: Received RSNIE in Assoc-Req: c014fff7, len = 22
Dec 23 18:16:42 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 18:16:42 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 18:16:42 kernel: PMK: c0136261, len = 32
Dec 23 18:16:42 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 18:16:42 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 18:16:42 kernel: concatenation=: 802c1b08, len = 76
Dec 23 18:16:42 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 95 c1 f9 f2
Dec 23 18:16:42 kernel: 0x0010 : d8 19 15 48 26 d5 9d 3f 53 34 f7 66 a3 b0 86 9f
Dec 23 18:16:42 kernel: 0x0020 : bb af b1 c5 25 47 1b f9 5f 3f 0a 7c fc 41 3b ea
Dec 23 18:16:42 kernel: 0x0030 : 20 ab 05 59 aa 66 ac cd cc d3 66 9f cb 04 4f b0
Dec 23 18:16:42 kernel: 0x0040 : 7d 84 27 bc 3d e1 10 f0 f0 fa 78 2b
Dec 23 18:43:16 kernel: !!! (0) Can't allocate reordering mpdu blk
Dec 23 18:45:09 kernel: Received RSNIE in Assoc-Req: c0151997, len = 22
Dec 23 18:45:09 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 18:45:09 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 18:45:10 kernel: PMK: c0136261, len = 32
Dec 23 18:45:10 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 18:45:10 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 18:45:10 kernel: concatenation=: 802c1b08, len = 76
Dec 23 18:45:10 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 9a d0 29 7f
Dec 23 18:45:10 kernel: 0x0010 : 4b fa 40 58 fd 3d d3 d5 9e af f5 79 57 94 bc a3
Dec 23 18:45:10 kernel: 0x0020 : 35 cd 51 95 8c af ca f2 a8 6c 79 37 e0 ad 38 b9
Dec 23 18:45:10 kernel: 0x0030 : 48 59 0d fb fa 98 f6 7b c4 c0 e5 ee b8 d9 eb 9c
Dec 23 18:45:10 kernel: 0x0040 : 93 70 82 39 0e 96 a3 66 02 79 9a f5
Dec 23 19:05:59 kernel: Received RSNIE in Assoc-Req: c0156677, len = 22
Dec 23 19:05:59 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 19:05:59 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 19:05:59 kernel: PMK: c0136261, len = 32
Dec 23 19:05:59 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 19:05:59 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 19:05:59 kernel: concatenation=: 802c1b08, len = 76
Dec 23 19:06:00 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 76 66 d4 0b
Dec 23 19:06:00 kernel: 0x0010 : f7 4a 9d e9 50 9b 03 b3 d7 93 7f 6b 08 cc 8e cd
Dec 23 19:06:00 kernel: 0x0020 : c3 c6 a1 07 4b 94 70 fc 1f 52 7b bf 83 7a e4 2a
Dec 23 19:06:00 kernel: 0x0030 : bd 54 15 5b 55 27 56 c2 b6 14 61 48 f5 b8 ad c3
Dec 23 19:06:00 kernel: 0x0040 : 6e 1f 8f 00 f0 03 80 1b ff 27 f9 3c
Dec 23 19:17:58 kernel: Received RSNIE in Assoc-Req: c0150cc7, len = 22
Dec 23 19:17:58 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 19:17:58 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 19:17:58 kernel: PMK: c0136261, len = 32
Dec 23 19:17:58 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 19:17:58 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 19:17:58 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 19:17:58 kernel: 0x0000 : 10 bf 48 81 b5 68 d0 23 db 52 bd f7 2c ca 33 54
Dec 23 19:17:58 kernel: 0x0010 : 9a a7 aa 7e a7 e5 81 ad f2 94 d6 b7 6b 79 b7 9a
Dec 23 19:17:58 kernel: 0x0020 : bc d2 cd 25 d2 5f 92 fd 68 14 81 45 98 a1 6b 0b
Dec 23 19:17:58 kernel: 0x0030 : aa 14 48 fb 1a fb e7 b7 5c e3 09 b1 a4 98 d8 fd
Dec 23 19:17:58 kernel: 0x0040 : 09 ca 4e 85 cf 04 3b bb e3 ac b9 ec
Dec 23 19:20:52 kernel: Received RSNIE in Assoc-Req: c015132f, len = 22
Dec 23 19:20:52 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 19:20:52 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 19:20:52 kernel: PMK: c0136261, len = 32
Dec 23 19:20:52 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 19:20:52 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 19:20:52 kernel: concatenation=: 802c1b08, len = 76
Dec 23 19:20:52 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 01 f6 8a a3
Dec 23 19:20:52 kernel: 0x0010 : 5d f8 3c e5 7f e9 54 ab f0 1d 8e 93 aa aa 21 ba
Dec 23 19:20:52 kernel: 0x0020 : eb 6f 71 f6 08 d9 78 73 bb 22 0a 35 c7 17 8e 83
Dec 23 19:20:52 kernel: 0x0030 : 74 1d be 2c f1 64 8b 23 4d cd 6e 68 19 7f cb fb
Dec 23 19:20:52 kernel: 0x0040 : a0 20 fd f3 10 60 f9 f5 cf ad 82 97
Dec 23 19:43:18 kernel: !!! (0) Can't allocate reordering mpdu blk
Dec 23 19:54:28 kernel: Received RSNIE in Assoc-Req: c0150cc7, len = 22
Dec 23 19:54:28 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 19:54:28 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 19:54:28 kernel: PMK: c0136261, len = 32
Dec 23 19:54:28 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 19:54:28 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 19:54:28 kernel: concatenation=: 802c1b08, len = 76
Dec 23 19:54:28 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 3c 5e 37 d7
Dec 23 19:54:28 kernel: 0x0010 : 03 27 46 4d 4d 51 4a 5a eb e3 fa 75 8b ea 09 56
Dec 23 19:54:28 kernel: 0x0020 : 61 b1 5d c3 05 1b 5e 20 77 7f 57 ba 72 d0 96 80
Dec 23 19:54:28 kernel: 0x0030 : 4b fb 40 4d fd 94 13 59 9a c8 29 b8 64 78 23 c0
Dec 23 19:54:28 kernel: 0x0040 : 1e 04 0f d9 7e cf ec f1 98 77 3c 42
Dec 23 20:01:07 kernel: Received RSNIE in Assoc-Req: c0156677, len = 22
Dec 23 20:01:07 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 20:01:07 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 20:01:08 kernel: PMK: c0136261, len = 32
Dec 23 20:01:08 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 20:01:08 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 20:01:08 kernel: concatenation=: 802c1b08, len = 76
Dec 23 20:01:08 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 09 14 b7 5f
Dec 23 20:01:08 kernel: 0x0010 : 45 03 af c6 81 ca e3 57 1a bc d5 e1 5e 10 f0 83
Dec 23 20:01:08 kernel: 0x0020 : f7 c1 41 f2 f0 6e 06 ea 37 51 8a e8 b5 f5 f5 00
Dec 23 20:01:08 kernel: 0x0030 : e4 07 fe 7b 7b e8 94 d1 3b 78 6d 7c cd 2e 66 6e
Dec 23 20:01:08 kernel: 0x0040 : 02 8c 41 25 1e 5f 8d a8 af 45 cf 67
Dec 23 20:13:16 kernel: Received RSNIE in Assoc-Req: c014f32f, len = 22
Dec 23 20:13:16 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 20:13:16 kernel: 0x0010 : 00 0f ac 02 00 00
Dec 23 20:13:18 kernel: PMK: c0136261, len = 32
Dec 23 20:13:18 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 20:13:18 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 20:13:18 kernel: concatenation=: 802c1ad8, len = 76
Dec 23 20:13:18 kernel: 0x0000 : 10 bf 48 81 b5 68 88 30 8a 49 26 9c 7c 14 0a e3
Dec 23 20:13:18 kernel: 0x0010 : 2f 9d 5c 13 72 a6 48 6b 1c aa 88 73 3d 48 cb f3
Dec 23 20:13:18 kernel: 0x0020 : 9f 3d 5a 7d 85 f3 c4 c6 bf d6 27 ac 92 d5 1b 51
Dec 23 20:13:18 kernel: 0x0030 : 9c 63 bc 39 f0 7c d7 f6 90 5f 59 1f 55 a7 d2 3f
Dec 23 20:13:18 kernel: 0x0040 : 29 54 27 c0 7c 6b 78 56 7f ac 1a 83
Dec 23 20:14:08 kernel: Received RSNIE in Assoc-Req: c015132f, len = 22
Dec 23 20:14:08 kernel: 0x0000 : 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
Dec 23 20:14:08 kernel: 0x0010 : 00 0f ac 02 0c 00
Dec 23 20:14:10 kernel: PMK: c0136261, len = 32
Dec 23 20:14:10 kernel: 0x0000 : de 0d 23 90 98 da b1 0f 8e 12 e9 20 41 a6 75 0d
Dec 23 20:14:10 kernel: 0x0010 : 75 da 86 69 8f 1d 9f ee cf 50 08 81 7b e2 f6 b1
Dec 23 20:14:10 kernel: concatenation=: 802c1b08, len = 76
Dec 23 20:14:10 kernel: 0x0000 : 10 bf 48 81 b5 68 48 60 bc 7e c6 d0 3e ea 11 51
Dec 23 20:14:10 kernel: 0x0010 : 75 73 ab 9e 5c f7 18 45 7b a5 22 d2 16 90 b4 81
Dec 23 20:14:10 kernel: 0x0020 : a4 0d bf 21 06 f6 37 b5 bd a8 12 bf 61 6b e2 af
Dec 23 20:14:10 kernel: 0x0030 : 69 a8 32 93 3a 07 5e 90 b6 77 0c 66 ef a8 e6 fa
Dec 23 20:14:10 kernel: 0x0040 : c8 25 24 d9 ce a4 64 6a 20 e1 a0 59
