Issues with Asus DSL-N55U
13 Sep 2009
Maidstone, Kent
I'm having some problems with my router. Last night I couldn't connect to the Internet so I restarted it. When I did, I found that the ADSL light would come on, and the light showing that an ethernet cable is plugged into one of the ports, but none of the others. Not even the power light is on. It's not transmitting a wi-fi signal regardless of which position the switch is on and when plugged directly to a PC the computer can't identify it.
I have no way to get onto the settings or do anything- any suggestions as to where to start would be great!
Turn it on, hold the reset switch for about 30 seconds. /Release
It will blank all settings (assuming it's still working)
