- 15 Dec 2011
Hello,
Appreciate any thoughts on an issue I am having as I've run out of ideas.
Firstly have an oil boiler which runs heating through radiators and heats water in a unvented indirect cylinder.
Cylinder also has immersion option which i am getting by on at the min.
Essentially went for a shower few days ago and noticed water was a bit cool.
Boiler is set to heat water for hour in morning and hour at night.
Went to boiler and boosted water through hive app.
Boiler fired up, port valve opens and hot water starts to flow to cylinder (feel pipes) - same with return from cylinder.
But boiler only stays on for 3-4mins then Boiler turns off - almost like it thinks water is at temp.
At this point Boiler will not fire up again.
I thought it might be faulty thermostat on cylinder so replaced this including probes - no difference in behaviour.
I did notice a drip coming out of tundra but not like flowing and prob only once every 5 mins you get a single drip.
Heating works fine.
Could HW issue be anything to do with drip? Should I check expansion vessel pressure?
Immersion side works fine.
Appreciate any advice.
Heating works fine.
