issues with MSI G-45 Z787 MB
25 Mar 2013
Redditch
Hi All
I seem to be having issues with the MSI Z787-45 Gaming motherboard
its supposed to be good for over clocking but if i change anything it just crashes
Anybody else having issues??
plus trying to remove GPU from the PCI-E slots is super difficult as the clips to hold it in get stuck!!
:mad:
Is there a function called "oc genie" in the BIOS or a button on the board? if you apply this does it work.
You are using a "K" CPU?
