Issues with "reserved memory"
3 Dec 2011
Aberdeen
I've just bought a laptop (lenovo s145 AMD Athlon w/ vega graphics) which was on sale and came across a strange memory issue.
it had 3.4GB useable and 600MB hardware reserved which was fine, I threw in another 4GB for a total of 8GB now my issue is that it has 5.9GB usable and 2.1 hardware reserved which i think is a bit much for a built in low end GPU
I've not seen any option in the bios to change the amount i've flashed the bios to hope maybe it would add a setting but that isn't the case and there is still no option.
As suggested by a friend i have changed the MS config to use all ram but that didn't fix the issue
if anyone can suggest something i havn't tried it would be much appreciated
It's reserving some of the RAM for the graphics, it will always need some RAM for the graphics because it doesn't have a dedicated graphics card. As you've added more RAM the laptop has reserved more to help with better graphics - nothing wrong with it.
Even with a proper GPU it has got to reserve something (bit like a page file is needed by some software to work properly even if never used), mines is at 63MB :D
Yes they know that
Their issue is that normally you can go in the bios and and alter the amount it's reserving
Usually goes something like
8mb~16mb~32mb~64mb~128mb~256mb
Or similar
They aren't finding that option in the bios which I think is something to do with AMD AGESA
Theirs is reserving over 2gb
As said above i have no problem with that BUT 2GB is way too much considering this igpu is like half the speed of a GT1030.
