Issues with the CPU cooler size
5 Apr 2011
Hi! I just received my parts for the new pc.
i7 2600k
Lian li PC-X500FX
Corsair H70
Fatal1ty P67
12 gb Corsair Vengeance 1600mhz
2x 6950
1 intel ssd 120 gb
9.5 tb hdd's
850 w psu
Dell U2711
My problem is that the h70 doesent fit if i try to mount it the usual way so i decided to turn it 90 degrees, i could mount it but when i attached the sidepanel, the H70 radiator was sticking 1-2 cm out of the case.
So does anyone have a suggestion for how i can fix this?
If not, what other coolers can i use?
