- 3 Jan 2009
- Bedfordshire
Thought i would post in here, as seems to make sense.
I have brought a cheapish cctv wireless 2.4ghz system. Picture quality is really good!!!
I am using the system to be able to check inside guttering, to see if its blocked.
Problem before even installing it, is range and interference.
it has a standard SMA type connector on the receiver. So i could purchase a hi gain Ariel. Would that help As distance seems to be the problem.
At the moment we are losing signal at around 10-20 meters, through like walls etc. With a hi gain Ariel, is it like its fooling the camera into thinking that the receiver is closer, as we are using this Ariel ?
thanks
thanks
