isys.exe
1 Mar 2007
Portsmouth
Anyone have any info on this, nothing about it on google. Get this message each time I boot up. :confused:
Find out where the file is located.
Windows search should be fine for that, might need to tick "seach in hidden files".
If its in the ESET program files folder it's likely to be something to do with NOD32.
nah its in the system32 folder, as an application. But its in the C drive, and iam running vista on my E drive. Ive not used xp for weeks now.
Does the exe load on startup?....
You could always shutdown the exe, move it from the folder (dont delete) and see if any problems occur with software as a result.
Problem is, google pulls up zilch on it, and it could be something related to MS, or then again perhaps not....
You could always submit it to one of those virus submission systems and let them check the file.
