I recently have transferred all my music and stuff onto my laptop with windows 7.
I had to autherize my itouch on the computer ( this is the 2nd pc its been on and i have 3 other pcs i can autherize the itouch on )
Right now iv imported all my data into the itunes. Perfect all fine. But when i plug my itouch in, sometimes it comes up "ERROR ON MARCS ITOUCH" then it closes, then i take out the usb link then stick it back in and it works fine, then it comes to syncing...when i try syncing songs it does all the syncing process...but doesnt go on the itouch? then when i try syncing again it comes up " Another iPod has previously been synced to this libary. Do you wish to start a new iPod?" i click yes and all that and it deletes everything. Then i go and sync it again and it still does the same thing, nothing comes on the itouch. Then i plug it back in and it does all this process again. I did the same with photos, movies and apps..Only the apps are going onto the itouch.
anyone got any ideas?
I had to delete older stuff on the itouch because iv sorted out all my music and now it isnt in 1 folder, that folder isnt on my pc so i deleted it plus the music. But still shouldn't this of just sorted it out on the itouch instead of deleting like its a new music?
