Itouch - video episodes in order
6 Jun 2005
I have been fiddling with my first videos and no matter what I use, I cant get a bought tv show (Babylon 5) to appear on my itouch in episode order
Itunes lists as it should be (with no applied sorting) however it imported seemingly randomly
I even tried editing the name of the episode with 1:, 2: etc at the beginning - even that appears backwards (with 1 at the bottom)
have you tried selecting 'Get Info' on each file within itunes, making sure the video type is set to TV Show, and then adding the episode numbers in the appropriate field?
All that is set correctly (Genre is set as TV Show, or did you mean something else as video type, with track number indicating correctly the episode number)
All the cd's work fine, but this tv series always appears wrong
These are the settings I'm referring to:
Been away for the weekend - I have to admit I dont recall that tab at all, *** whole thing looks different
Will double check when I get home
