ok, it's darn cold, gotta have fun...
P4 2.8GHz (at stock) with modified bigwater SE water cooling kit...
ATI radeon X1650 pro with waterblock...
my 120mm rad + 120mm fan it aprox 4 meters away from PC. I got a pair of pipes leading round the back of my desk and monitors and out the window...
so...
outside temp is 3C reported by a digital thermometer I baught with long lead for sensor...
room temp is 21C reported by same thermomitor as above...
CPU no load is 25C reported by MBM...
CPU 50% load is 27C reported by MBM...
CPU water block temp is 23C reported by fan controler...
Primary HD temp 28C reported by fan controler...
Northbridge temp 55C reported by fan controler...
GPU temp 22C reported by ATI tray tools from omega drivers...
Voltages...
Core0 1.5V
Core1 1.3V
3.3V 2.66V
5V 5.0V
12V 11.50V - -11.8V (unstable)
-12V 11.50V - -11.8V (unstable)
-5V 5.0V
I know about the 12V lines... my 500W PSU got blown up last week when we had a power cut, and went pop, fizzle, pop, BANG when the power came back on... Luckerly, rest of PC is OK...
so... what do we think?
Don't ask for pix, it's a right mess in my PC after having to pull the powersupply... once i sort it out, you'll have pix...
:edit
Still 3C outside... however water block temp dropped to 19C, not sure why the change... yet...
Also, the res is darn cold!
i'm going bed now (1AM) in the morning i'll look at the temp delta's. I'm also going to move the twmp sensor that on one of my hard drives onto my GPU water block since MBM has now decided it's going to display the HD onboard temps now...
so...
Voltages...
Core0 1.5V
Core1 1.3V
3.3V 2.66V
5V 5.0V
-5V 5.0V
:edit
...then overclock the hell out of it
