OK, I don't get bsod's
I do have issues with possibly the gfx card sometimes, on start up the screen goes all weird and pixely liney - re-boot and it'll be fine 9.5/10
sometimes the pc seems a bit slow, mostly it is ok, it generally doesn't go into sleep mode if left and will just stay on.
I'm at work right now so don't have all the specs atm (should have done this thread last night at home I guess!)
it is:
Intel Q9450 processor
Asus P5Q P45 chipset mobo
ATI 5770 gfx
Velociraptor 150gb as 'windows' hdd
Windows vista HP
PSU Epsilon 700w
The system isn't overclocked, pretty much everything was bought on the MM probably a good few years old now!
I've run memtest and windows memory - no errors, although only for an hour or so each - maybe longer
I've done a full cycle of hotCPU tester and no errors
Now the main problem is I don't have spare gfx cards to swap and see
What would your course of action be guys?
Thanks
Another quickie..... would you bother going to Windows 7 from Vista??
it is:
ATI 5770 gfx
Windows vista HP
PSU Epsilon 700w
Thanks
