Its BBQ weather so break out some tunes!!
20 Jul 2009
The bleak North East arm pit of Britain
You cant beat the Edifier R1600T for quality and performance at £77.99inc! At £49.99inc you would be forgiven to think they were priced too cheap! BBQ season is here so break out the BBQ with some burgers, beers and some awesome tunes!
Edifier R1600T Studio Plus 2.0 Monitors ** BBQ SPECIAL!! ** @ £49.99 inc VAT
** PRE ORDER PRICE **
The Edifier R1600T Plus is a professional low-noise amplifier with all wood enclosure. The high performance crossover provides superior coverage while magnetic shielding prevents interference. The 5-inch bass driver is designed using a composite cone structure for a truly balanced acoustic. Built-in, side-mounted controls mean volume, treble and bass are at your fingertips. Dual RCA inputs allow connection of two additional devices for maximum flexibility in your set-up.
- Professional low-noise amplifier coupled with high performance crossover.
- 4.5inch bass driver - designed using a composite cone structure for a balanced acoustic.
- Silk diaphragm 18 mm tweeter with aluminum phase plug.
- Side mounted rotary volume, bass and treble controls.
- All wood enclosure.
- Power Output: RMS 2 × 16W
- Signal to noise ratio: 85 dBA
- Distortion: 0.1%
- Bass unit: 5 inch (120mm), magnetically shielded, 6ohm
- Tweeter unit: 18mm silk dome tweeter, magnetically shielded, 4 ohm
- Input impedance: 10K ohm
- Input sensitivity: 550 mV ± 50 mV.
- What's in the box:
- 1 x Active speaker
- 1 x Passive speaker
- 1 x 3.5mm to RCA connector cable
- Audio connecting cable
- User manual
- Dimensions: 152(W) x 252(H) x 228(D) (mm)
Was £77.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
How long will this price stay up as I dont get paid till 2 weeks time and OCUK take out money immediately on pre-orders :(
Whilst its sunny!!
If the weather fails tomorrow the price comes down, if the weather is nice for 3 weeks its up for 3 weeks! :)
Weather looks to be good for the next 10 days at least, keep your fingers crossed ;)
Whilst its sunny!!
Is that right?
Hmmm, were talking about English weather right since N.Ireland while still getting good weather, still not as good as English weather!
If it can go on for 12 days then Ill get one as my 3-4 years old advent mp3 speakers are starting to loose signal/make screeching noise.
Hmm.. Just realised its +£10 for P&P to NI :(
Is that right?
Still a bargain though :)
Its a big chunk of the price, wouldn't notice it if I was spending hundreds but you can feel it for £50, thats 20% of the item price! :eek:
