** ITS HOT TODAY!!! - HW LABS BLACK ICE RADIATORS - COMPLETE RANGE IN STOCK AT OCUK **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
We are proud to announce that we now carry every Hardware Labs Black Ice Radiator.
Hardware Labs are easily the market leaders in quality and performance.
We now offer a radiator from every part of their range,
high density, low density, thick, thin, standard layout, crossflow, 120mm and 140mm. You literally cannot go wrong with Black Ice.
not to mention, they have a Radiator at every price point.
CLICK HERE FOR THE FULL RANGE
Here are some of the highlight products from the range!
IN STOCK AND SHIPPING NOW!
Hardware Labs Black ICE Radiator GTX-Lite 120 @ £28.99 inc VAT
The Xtreme series from Black Ice radiators is the most powerful radiator series from Black Ice. This is the newest generation of Black Ice radiators which were redesigned significantly. The concept is the same as in the GT Stealth series, the radiators just have double the thickness to further improve cooling performance. Due to the use of extremely thin fins the fin density was increased significantly and therefore also even more the cooling capabilities of this radiator! This 120mm radiator for a single 120mm fan can be installed in virtually any, even very small cases. Despite its compact dimensions it has outstanding cooling capabilities! Of course a single 120mm radiator is not capable of cooling a full-grown Multi-GPU system, it is rather designed to silently cool Media PCs which require very small heat exchangers. And for such applications this radiator is perfect! Or multiple of these smaller radiators are installed which gives enough cooling performance for a more powerful and completely watercooled system! The Black Ice Xtreme radiators are made from brass and are equipped with soldered copper fins. The build quality is outstanding, the whole radiator is coated with a black finish. The radiators are designed to provide high cooling performance even with slow-spinning fans.
- Material: Soldered copper fins, brass casing and chambers
- Dimensions: (L x W x H): 155 x 120x 57 mm
- Connection threads: 2x G 1/4"
- Fan installation with M4 threads (on both sides)
- Weight: approx. 530g
Only £28.99 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator GT Stealth 140 @ £34.99 inc VAT
The Stealth series from Black Ice radiators is extremely thin in design but boasts impressive cooling performance. This is the newest generation of Black Ice radiators which were redesigned significantly. The concept is the same as in the Xtreme series, just in a thinner design which still allows outstanding cooling performance. Due to the use of extremely thin fins the fin density was increased significantly and therefore also the cooling capabilities of this radiator! The 140mm radiator for a single 140mm fan can be installed in virtually any, even very small cases. Despite its compact dimensions it has outstanding cooling capabilities! Of course a single 140mm radiator is not capable of cooling a full-grown Multi-GPU system, it is rather designed to silently cool Media PCs which require very small heat exchangers. And for such applications this radiator is perfect! Or multiple of these smaller radiators are installed which gives enough cooling performance for a more powerful and completely watercooled system! The Black Ice Stealth radiators are made from brass and are equipped with soldered copper fins. The build quality is outstanding, the whole radiator is coated with a black finish. The radiators are designed to provide high cooling performance even with slow-spinning fans.
- Dimensions: (L x W x H): 171 x 153 x 31.3mm
- Weight: approx. 550g
Only £34.99 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator GT Xtreme 140 @ £35.74 inc VAT
The Black Ice® GT Xtreme 140 brings true next generation PC radiator technology to a higher level using the new GTX core platform for 140mm fans.
The Black Ice® GTX140 uses a unique pre-cool/aftercool coolant flow configuration that increases heat transfer efficiency and internal system flow rates.
The Black Ice® GTX140 is the first effective dual-core 140mm PC radiator providing new systems with increased performance and thermal capacity.
Thread Size - 1/4"
Fan Compatibility - 140mm
Fan Spacing - N/A
Fan Mounting Points - Double Sided
Fins Per Inch - 20
Recommended Fan Speed - 1500 to 2500 RPM
Materials Copper Fins
Brass Construction
Bleed Valve Screw - No
Dimensions (W x D x H) - 153 x 54 x 171 mm
Weight - 520g
Special Features - Fans Can Be Mounted Either Side
Designed for 140mm Fans
M4 Fan Mounting Threads
Package Contents - 1 x Black Ice GTX140
4 x M4 Fan Mounting Screws
Only £35.74 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator GTX-Lite 240 @ £48.98 inc VAT
The radical redesign of the Black Ice core technology increases efficiency, this being the latest and most powerful addition of the Black Ice generation.The Lite version has reduced weight and size to improve easy installations while keeping the same level of performance.
Technical details:
Material: Copper fins soldered, pre-chambers of brass
Dimensions: (L x W x H): 275 x 120 x 54mm
Connection: 2x G 1 / 4 thread
Fan mounting with M4 thread (both sides)
Weight (empty / without connections): approx 890g
Only £48.98 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator GTS-Lite 240 @ £37.99 inc VAT
The Stealth series from Black Ice radiators is extremely thin in design but boasts impressive cooling performance. This is the newest generation of Black Ice radiators which were redesigned significantly. The concept is the same as in the Xtreme series, just in a thinner design which still allows outstanding cooling performance. Due to the use of extremely thin fins the fin density was increased significantly and therefore also the cooling capabilities of this radiator! This 240mm radiator for a two 120mm fans can be installed in virtually any, even very small cases. Despite its compact dimensions it has outstanding cooling capabilities! Of course a single 240mm radiator is not capable of cooling a full-grown Multi-GPU system, but for cooling the CPU and a single graphics card the radiator has plenty of performance. Or multiple radiators are installed which gives enough cooling performance for an even more powerful and completely watercooled system! The Black Ice Stealth radiators are made from brass and are equipped with soldered copper fins. The build quality is outstanding, the whole radiator is coated with a black finish. The radiators are designed to provide high cooling performance even with slow-spinning fans.
- Dimensions: (L x W x H): 275 x 120 x 29.6mm
- Weight: approx. 540g
Only £37.99 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator GT Stealth 280 @ £45.98 inc VAT
The Xtreme series from Black Ice radiators is the most powerful radiator series from Black Ice. This is the newest generation of Black Ice radiators which were redesigned significantly. The concept is the same as in the GT Stealth series, the radiators just have double the thickness to further improve cooling performance. Due to the use of extremely thin fins the fin density was increased significantly and therefore also even more the cooling capabilities of this radiator! This 280mm radiator for a two 140mm fans can be installed in virtually any, even very small case. Despite its compact dimensions it has outstanding cooling capabilities! Of course a Dual 280mm radiator is not capable of cooling a full-grown Multi-GPU system, but it has plenty of cooling power for a single CPU and graphics card. The Black Ice Xtreme radiators are made from brass and are equipped with soldered copper fins. The build quality is outstanding, the whole radiator is coated with a black finish. The radiators are designed to provide high cooling performance even with slow-spinning fans.
- Dimensions: (L x W x H): 316 x 153 x 55,7mm
Only £45.98 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator GTX-Lite 360 @ £50.99 inc VAT
The Black Ice® GTX360 is indeed a generational revolution from its traditional Xtreme case-mod professional origins. True second generation Black Ice GTX core design maximises cooling, flowrates and performance utilizing 3 x 120mm fans even in low RPM/noise conditions. Xtreme level perfomance, as expected comes with at the highest quality of design and construction to cater to the most discerning case-mod enthusiast.
Two-pass pre-cool/aftercool front-rear dual-core flow configuration with a 30% increase in internal flow rates.
Custom MaxFin™ 25 micron Copper Splitter Fin Configuration utilizing 45% thinner fin material yielding up to 50% less pressure drop.
Unique fin configuration eliminates intra-louver accumulation of dust particles for trouble free operation.
Radically optimized 20 FPI (Fins Per Inch) fin density providing dramatically increased heat transfer surface area.
Custom low-profile 2-row 19.0 x 1.2mm MaxFlow™ tubes with twice the waterside surface area of the GTS and 60% frontal area reduction for superior low air-resistance aerodynamics and lower internal flow requirements.
Yields up to 45% more heat exchange capacity than the Black Ice® Xtreme in both Stealth or Performance modes.
Achieves Black Ice® Xtreme level performance in stealth mode (low-noise/low-airflow conditions).
M4 Threaded Screw Holes for easier mounting and greater adaptability.
Now standard G 1/4" female threaded fittings.
Full high-temper brass structural construction for weight reduction and superior corrosion resistance.
High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme and most 120mm form factor radiators.Uses 100% Non-corrosive water-solluble fluxing process.Fully RoHS compliant.
Full electrostatic polyurethane painting finish for uniform coating with high temperature curing for increased finish durability.
Renowned Black Ice® quality.
Patent Pending Design.
Only £50.99 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator GT Stealth 360 - XFlow @ £46.99 inc VAT
For uncompromising performance are the new Black Ice ® GT Stealth radiators. The radical redesign of the Black Ice ® core technology increases efficiency, this currently latest and most powerful Black Ice generation, again significantly. So that the radiator for both projects and Overclocking Silent PC is suitable. When XFlow's offered here are not the connections on one side, but face each other diagonally. The advantage of this variation is especially noticeable in water cooling systems, which have a strong pump. The cooling medium flows directly and without change of direction through the radiator. The performance is increased significantly once again. The new arrangement of the lamellae ensures optimum cooling in a confined space. By using 45% thinner copper fins to get there with 50% less pressure - at the same time double-density disk. 30 fins per inch increase dramatically, and ensure the surface of a heat transfer that has no equal. Compared to the Black Ice ® Pro can be delivered faster to heat up to 20%. Due to the better heat transfer capability can slowly rotating fans are used. The cooling capacity of the system is maintained and the noise level can be further reduced significantly. The processing and very specifically in the painting of the radiators is top notch. M4 thread and the G 1 / 4 thread for the connecting holes ensure easy installation and maximum compatibility.
- Brass radiator with copper fins soldered
- G1/4" Thread
- Fan Mounting with M4 thread (both sides)
- Size: 415x135x30mm
Only £46.99 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator GT Xtreme 420 @ £99.98 inc VAT
The Xtreme series from Black Ice radiators is the most powerful radiator series from Black Ice. This is the newest generation of Black Ice radiators which were redesigned significantly. The concept is the same as in the GT Stealth series, the radiators just have double the thickness to further improve cooling performance. Due to the use of extremely thin fins the fin density was increased significantly and therefore also even more the cooling capabilities of this radiator! This 320mm radiator for a three 140mm fans can be installed in virtually any, even very small case. Despite its compact dimensions it has outstanding cooling capabilities! This triple radiator is capable of cooling even more powerful systems. The Black Ice Xtreme radiators are made from brass and are equipped with soldered copper fins. The build quality is outstanding, the whole radiator is coated with a black finish. The radiators are designed to provide high cooling performance even with slow-spinning fans.
- Dimensions: (L x W x H): 460 x 153 x 48mm
Only £99.98 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator GT Xtreme 560 @ £130.99 inc VAT
The Xtreme series from Black Ice radiators is the most powerful radiator series from Black Ice. This is the newest generation of Black Ice radiators which were redesigned significantly. The concept is the same as in the GT Stealth series, the radiators just have double the thickness to further improve cooling performance. Due to the use of extremely thin fins the fin density was increased significantly and therefore also even more the cooling capabilities of this radiator! This 560mm radiator for four 140mm fans can be installed in virtually any, even very small case. Despite its compact dimensions it has outstanding cooling capabilities! This quad radiator is capable of cooling even very poweful systems. The Black Ice Xtreme radiators are made from brass and are equipped with soldered copper fins. The build quality is outstanding, the whole radiator is coated with a black finish. The radiators are designed to provide high cooling performance even with slow-spinning fans.
- Dimensions: (L x W x H): 610 x 153 x 48mmmm
Only £130.99 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator SR1 560 @ £111.98 inc VAT
The Black Ice® SR1 platform is the new PC radiator technology from Hardware Labs designed for ultra-low airflow applications. Black Ice® SR1 radiators feature a custom compressed core width utilizing streamlined 45 micron copper fins giving it unparalleled performance from sub-800rpm to 2000rpm fans and flow constricted systems.
Features
• Two-pass u-flow configuration utilizing high-flow tubes for up to 40% increase in internal flow rates.
• Custom compressed core width to maximize airflow and enhance heat exchange.
• Optimized custom 9 FPI (Fins Per Inch) 45 micron copper maximized conductivity.
• Yields up to 30% more heat exchange capacity than the Black Ice® GTX in ultra-stealth operation mode up to 2000rpm.
• Built-in 15mm deep plenum for equalized core air pressure distribution.
• M4 Threaded Screw Holes for easier mounting and greater adaptability.
• Standard G 1/4" female threaded fittings.
• Full high-temper brass structural construction for weight reduction and superior corrosion resistance.
• High performance compact radiator compatible as an upgrade to the Black Ice® GTX560 and most 4x140mm fan form factor radiators.
• Uses 100% Non-corrosive water-soluble fluxing process.
• Fully RoHS compliant.
• Full electrostatic polyurethane painting finish for uniform coating with high temperature curing for increased finish durability.
• Carbon Black Finish
• Renowned Black Ice® quality.
• Patent Pending Design.
Dimensions
Width 153 mm
Height 605 mm
Thickness 55.9 mm
Only £111.98 inc VAT.
ORDER NOW
Could I whack a 280 or 240 in the top of my Fractal R3.
I would love to put my 560ti 448 under water with a bit of modding.
Also, would I still be able to take my pc to lan under water or would It leak everywhere. haha
It depends really. In theory there should be room bu the thing you need to look out for is if your motherboard has heat sinks around the socket that could obstruct the rad.
Is there something wrong with the pricing of the 240&360 gt stealth rads? As the 360 model is cheaper
Btw with an r3, you can't use a 240 rad in the roof, as the spacings are too wide
Maybe a little deal on the SR-1 rads this week RJK :D?? (240 & 140 :))
Its that kind of cheek that gets these things put on This Week Only!
I will see what. I can do. may not be this week but will be very soon if not.
Send me a message in trust with the stock codes you are interested in :)
