Its is complete!
30 Dec 2011
Essex
Hello guys,
I have finally built my mini-ITX build that you guys have so kindly helped me on. One problem I did encounter was that I snapped a pin of the USB 3.0 front header. I still have loads of usb 3.0 at the back though and I do not own any USB 3.0 devices so it doesn't really effect me really. For those who wanted a look soon a video will be posted to youtube on the channel name- LordCrispyDuck.
Next step overclocking; I have got it to 4.5GHz and have been testing it for ten minutes now with temps of 65-70 degrees. Is this too high and what can I do to fix it.
I followed this guide for the overclock exactly: http://www.overclock.net/t/1291703/ivy-bridge-overclocking-guide-asus-motherboards
Thanks.
Those temps are fine. I would only start to worry at 75 - 80.
I get about 67 on prime95 with my 4.6GHz overclock.
70 degrees running for an hour. How long should I go for?
I have a noctua dh-14. It was a very tight squeeze to fit in my prodigy. Speaking of that my optical drive cannot fit properly without me moving it forward so it is not flush. Is there any shorter optical drives smaller than this: Samsung SH-224BB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM
