It's not another spec me a watercooling case thread...
23 Sep 2009
London
I lied!
While you're here...
I've been using a twice modded TJ07 with 1x480 EX480 30mm thick and 1x240mm slim 15mm & 40mm (AX240) thick radiator in it since 2012 and fancy a change as it looks too out dated...
I like tempered glass so naturally I like the Lian Li PC-011 ROG, in White. Will it fit 2x360mm radiators top/bottom AND my Aquacomputer Aqualis XT res/pump (440ml) in the front? I also have two 980ti's that need to fit so sideways mount in that case won't work with two will it :( (Trying to put off getting a 1080Ti as I can't justify the slightly small performance gain, unless convinced otherwise :p)
Would I be able to stick the Aquaero controller w/LCD in there somewhere too? Is there anything out there that looks just as good but better for the OTT watercooling buff and maybe not as heavy or large as a TJ07 as that case seems to destroy (my spine and) every table I've ever had it on? Maybe an InWin 909?
EDIT: Wait, the ROG version doesn't come in white? Awww man! :(
