Its over 9,000!!!!!
Caporegime
17 Mar 2012
ARC-L1, Stanton System
Overclocker Pushes DDR5 to over 10,000 MT/s On Ryzen 8700G. (this with DDR5 7200, OC result 10,600 MT/s)
AMD have been working on their DDR memory speeds over the last few months, recently with BIOS updates improving high speed memory on Ryzen 7000 series, also claiming that memory speeds of 8,000 can be reasonably expected on Ryzen 8000G series.
Do we think AMD got a little tired of the ram speed criticism's? Well.... How's that? Hu??? :D
They need this gargantuan memory overclock to undo the the performance lost from their STAPM ineptitude. :D
That's the skin heat safety thing they introduced for handhealds, its already been fixed, it was an easy one.
I take it ram speeds makes much more difference now then? I know it was always negligible.
not sure if it directly translates to the "proper" AMD desktop chips though...the 8700G is basically a laptop chip without a separate i/o die
